Question about Boating
1995 sea doo speedster why wont it receive fuel to the carburetor?
3 Suggested Answers
  • 7 Answers
SOURCE: 2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
Posted on Aug 28, 2012
  • 3176 Answers
SOURCE: I have a 2004 sea doo with a starting problem. It will turn over 3 or 4 times and then just click. I have a new battery and have cleaned all terminals within reach.
Perhaps.
I suggest you test the theory by bypassing the relay and/or energising the starter motor manually using a jumper lead, a suitable screwdriver or similar or a remote starter switch.
Posted on Mar 19, 2017
1990 ski doo mach 1
You have dirt in the carburetor jets and or passages, clean the fuel tank and rebuild the carb.
Dec 20, 2016 | Winter Sports
2001 sea doo speedster overheating
bad water pump, get it replaced
Aug 27, 2015 | Boating
I have some seadoos that have been stored for a long time what all should I do to get them running again
clean the fuel and air systems, to include the carburetors. charge the batteries. Fill with good fresh fuel and fire them up.
Apr 29, 2015 | Sea Doo Boating
What do I need to do after 10 years of storage.To put a 1992 Sea Doo in water?
Change fluids, Check hull for bouyancy flaws, replace plugs, clean carbs or rebuild them. Most old engines get gummed up after long term storage if the fuel was not completely drained. Another possibility is that the bearings may be damaged from years of condensation and and drying. It happens sometimes and sometimes you just get lucky. Had a ducati paso 750 that blew the race on the bearings because they were deteriorated after years of storage in climate controlled space. Was fine then one day the bearings came apart in the engine and chewed it up.
Jul 18, 2014 | WSM 1992-1996 Sea Doo Gts 580cc Jet Ski...
What causes a 1993 seadoo engine to bog down then take off, then bog down?
fuel mixing issue. A good tune up is recommended. Focus on the carburetor.
Jun 07, 2014 | Sea-Doo US Seadoo Sea doo pump off 1993 XP...
Help!! '97 Seadoo GTI, just had the carburetor rebuild, replaced the Rectifier Regulator, replaced the spark plugs and recharged the battery. But the jet ski would only reach 40mph and it would bog down to...
Sounds like you might have the rotary valve in the wrong position. Also you are going to need to replace your fuel lines and check the fuel petcock for any blockage. Lastly, when u rebuilt this carb did you check the tiny fuel filter behind the pump body?
Sep 23, 2013 | Sea-Doo US Boating
96 seaboo will not go full speed in water, but full rpm out of water
carbs need cleaning and check the pulse jet that squirts fuel on set off , fuel pump diaphrams ok ?
Sep 08, 2013 | Sea-Doo US Seadoo sea doo cdi ignition...
I have a 1996 sea doo xp model jetski, i have rebuilt the carbs and replaced all the fuel lines. i also removed the gas tank and thouroughly cleaned the whole fuel system .. it is still bogging a bit when...
any vehicle will bog if you give it full throttle from a standstill. You are dumping huge amounts of fuel into a engine that is not spinning fast enough to burn it.
Take it to a Seedoo dealer and get them to calibrate the carb. They have the diagnostic equipment,exhaust sniffer and the know how to do it. Also on twin carbs, they have to be balanced. They have the vacuum gauges to do that. It is not an expensive exercise.
Aug 08, 2017 | Boating
Seadoo jetski
have you got any fault codes on the screen ? has the intercooler been checked for leaking in to the intake manifold ? press the set button 5 times to see codes if any ! how old is the fuel ? over 5mths then replace !!
Jun 20, 2013 | Boating
Jul 25, 2012 | New Ray 112 Scale Bombardier Sea-Doo XP...
Boating Logo
348 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
