Question about Nikon D80 Digital Camera with 18-135mm Lens
Job-r error code
Error code job-r keeps coming up?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
How to fix 49.2fa7 error
Try again with out connecting network cable or usb cable . If the message does not come on, you have a bad job trying to print each time the printers signals the network it is ready. You need to delete the bad job. Sometimes you can keep the network cable disconnected until it comes to ready and then plug it in and keep hitting the cancel button in attempt to cancel the job, but most times you need to delete the job at the computer or server which is sending it.
Dec 24, 2015 | HP COLOUR LASERJET CP4525DN Printer
Error code GARO W1234 keeps coming up why
1. unplug data cable
2. go to service mode
Aug 26, 2015 | Canon imagePROGRAF iPF8000 Printer
What is error code F248
F248 is a corrupt print job. Cancel all prints jobs. Happens most often when printing from the Internet. The newer machine (3500i - 3501i) have a firmware update correcting this error code.
Oct 01, 2014 | Copystar Cs-250ci
What does error 49.4C02 Service error on HP Printer 2420dn
it is a bad or print job the 1st time if it keeps popping the code then
you need to flash the firmware which is easy. use a usb hook it to a laptop undo the network so no can send a job to it set up laptop to
print to it, so go to hp.com load driver then print then on the same page from hp download firmware and the installer read the how to then flash it,let it run its cycle it will turn on and off 1 or 2 times then it will come up to ready. if it keeps popping the code then check your cat 5 cables make sure they r in good shape if so, then ur looking at a
bad formatter board, $200 up is the price. go to ebay or look for on google a company that buys and sell used ones un plug remove to
screws install formatter turn on and in the printer put your ip gateway
and sub and ur good to go. but 75% of the time its firmware
Jul 13, 2014 | HP LaserJet 4600dn Color Printer
Hp color lj cp4025 error 49.2fa7 code how to clear
see
HP color LaserJet cp4525dn error 49 2fa7
suggestion.
Disconnect the network cable or usb cable and try again. If the message does not come on, you have a bad job trying to print each time the printers signals the network it is ready. You need to delete the bad job. Sometimes you can keep the network cable disconnected until it comes to ready and then plug it in and keep hitting the cancel button in attempt to cancel the job, but most times you need to delete the job at the computer or server which is sending it.
Jun 23, 2014 | Office Equipment & Supplies
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Error code 4021
4021 indicates Print job power failure
When there are running jobs, perform the job in error again after the completion of the running jobs.If the error still occurs, turn the power OFF and then back ON, and perform the job again.
Jun 23, 2012 | Toshiba E-Studio 456 Copier
Doc 12 error code 9-343
i had similar problem a week ago running black only job on extra heavy card stock.
there is black toner built up. when you run black only copy with little toner use, it builds up toner in black developer and motor could not run.
always mix black and color jobs and run alternate, so there is no excesses in any color. or cheaper way how i did without paying color clicks.
i got rid of excess black in following manner.
took 11x17 white sheet, copied as negative (solid black) and ran 30-50 black copies, which drained all excess black and then continued with job.
hope it works for you or get professional help or you will lose motherboard and motor if you just follow instruction as it tells you on error screen... switch off and switch on. do not keep on repeating.
Oct 23, 2008 | Xerox DocuColor 12 Printer
ZANUSSI ZWF1437W WASHING MACHINE
yes sounds like door interlock cheap and easy diy job goodluck and unplug regards jason
Jun 14, 2008 | Zanussi ZWF1430W Front Load Washer
Nikon D80 Digital Camera with 18-135mm Lens Logo
73 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
