Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Problem for Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright...
Replaced belts and brush roller will not rotate.
By jpbelski on Jul 10, 2009
Solution #1
posted on Nov 01, 2009
Not Rated)
tirechains1
Rank: Apprentice
Rating: 0%, 0 votes
check to see if the spindle (small pencil-thin metal rod) is spinning where it projects from the motor. the belt wraps around this rod. if the rod is spinning when the vac is turned on your brush roller could be jammed. the bearing in the far sides of the brush roller frequently pick of long threads and hair and will stop the brush roller or the bearings sometimes overheat when worn and plastic will melt in this area causing stoppage.
Was this helpful?
Yes
No
Popular Solutions for Hoover U6437-900 / U6439-900
Questions and Unsolved Problems for Hoover U6437-900 / U6439-900
Do you recommend Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum?
Answer
Answer
on/off switch broken on hoover windtunnel model U6476-910
Answer
Hoover Windtunnel will not turn on, I think I need to replace on off switch... any suggestions?
Answer
I have hoover WindTunnel Self Propelled Vacuum and the Brush roller does not work. The hose works. I... (More)
Answer
the light on my hoover wind tunnel self propelled bag vacuum cleaner is stuck on the red light and... (More)
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in Newport, KY
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
