HOW TO RECORD A GREETING
ON MY PERSONAL STATION
  • 20 Answers
SOURCE: Recorded message after my personalized greeting
This isn't in the phone. It's in your voicemail preferences. Listen to all options in your voicemail settings. Just keep listening for an option number for settings after it tells you that you do or dont have messages. If you dont find something fairly obvious call *611 and tech support should be able to talk you through it. Call from a phone other than the razr.
Posted on Jun 16, 2008
SOURCE: Personal Greeting
Go to your personal greeting and press delete twice and press rls this will delete your personal greeting and you can re-record your new personal greeting I hope this helps you!
Posted on Dec 03, 2008
cnavarro
  • 2460 Answers
SOURCE: HOW DO INDIVIDUALS RECORD PERSONAL GREETINGS?
It's done in the same manner. You dial the voice mail port from the extension and it should gate into the user's mailbox...if it exists.
By default the extension is 165 or 500, but it could be different.
If they never had working voice mail, they'll probably get the tutorial. If they did and it's someone else's box, you can delete it as an administrator (from 999 not 998) and add it again and it will clear the box and come up as a new user.
Once the box is established from remote or a different extension than their own, they can press #6 *ext at the main greeting to access their mailbox.
Carl
Posted on Jan 19, 2009
  • 5387 Answers
SOURCE: I am trying to record
Which model phone do you have? For the CL82509 and related DECT 6.0, you need to set the outgoing message from the handset when the answering machine is on. (It can be turned on from the handset).
For the outgoing message: with the handset in Idle mode, press Menu/Select. Use the up (Dir) and down (CID) arrows to highlight Ans Sys Setup. Then press Menu/Select. Use the same arrow keys to select Announcement and press Menu/Select again. Press 7 to record a new announcement. At the tone, speak your message clearly then press 5 when you have ended the message. The message will play back.
This model's manual is available here: http://att.vtp-media.com/ecp/documents/product_Product/132/UserManual/5995/cl82509_manual_USA_i6.pdf . See page 15 to set the answering system outgoing message. (This is different than Voicemail. To set up Voicemail, you will need to see your telephone provider's documentation.)
Most AT&T phone manuals are available here: http://telephones.att.com/att/index.cfm/product-support/manuals/ .
I hope this helps.
Posted on Apr 01, 2011
SOURCE: I have a Siemens Gigaset 8800. I am trying to record a personal greeting. (the quick greeting that it comes with is the one playing) I've followed the instructions. The phone responds "empty record
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027395.pdf
http://www.barclayent.com/manuals/Siemens%208825%20Quick%20Start.pdf
Hi please find above links for your user/QS manual.
Now if you have done it successfully in the past and you are indeed doing the exact same procedure, but it fails, then the only conclusion one can come to is that the unit has faulted? I have seen similar types of faults on these and other types before, and they always present the same symptoms you indicate. However use this top manual and go to page 55 and do that procedure, and see if that will work? If it still will not work OK, then you have little option but to get it repaired, use the process indicated in the manual, as to repair. You may like to only first just ask for a "Quote", and once appraised of costings etc, you can then make up your mind as to repair or replace?
Posted on Oct 24, 2011
How do I record my voice mail greeting in my personal cell phone
You didn't say what type & kind of phone you have (iphone or android) or phone service you have (they all do them slightly different). If you dial your own phone number into your cell phone, that should access your voice mail. I have a Sprint Android, so
  1. Press 3 for Personal Options
  2. Press 2 for Greetings
  3. Press 1 to Change Greeting
  4. Press 1 to Record personal greeting or press 2 to select the standard greeting
  5. Press # to End Recording
  6. Press 1 to Confirm Greeting
Change your Sprint personal voicemail greeting
Nov 15, 2016 | Lands Phones
I lost manual. I need to know change message when will be out of town answering message.
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a
call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own
personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the
messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the
system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the
announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded
greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Dec 03, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do i change my vociemail message for the Dect 6.0?
Reording a Personal Greeting Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting.
To keep this greeting: Do nothing.. To switch to the other greeting: Press 6 while the system is playing the current greeting. Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last greeting you hear is used as the current greeting.
Deleting Your Personal Greeting You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous section to switch the greeting.)
While the personal greeting is playing, press 4. The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Oct 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
May 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Feb 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
I recently bought a dect 6.0 digital answering system,and a friend put the first message on for me,then lost the manual,and now I can't figure out how to record a new message.Help!
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
  1. Press the Message icon (letter)/mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Jan 06, 2010 | Uniden DECT 6.0 Cordless Telephone...
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Nov 15, 2009 | Lands Phones
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Personal Greeting
Jun 13, 2008 | NorStar Meridian 9516 Corded Phone
150 people viewed this question
 Grubhead
Grubhead
