I replaced the pump 2 months ago because it was not draining at all, and the machine worked fine until 2 days ago. The error showing up for the spin problem is the first 4 lights in the 8 light series are glowing and the machine beeps very often.
SOURCE: Washer won't spin or drain
whats the make of your washer, if its the older models it might be the lid switch, switch might be defective, but i still need the make/brand of the unit to be more specific.
SOURCE: problem draining &spinning
Get the strings coins and sand out the pump and retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
