Question about Toshiba Se-r0301 Q152 Remote Control
I have sound only, and no picture on AV1 - Toshiba Se-r0301 Q152 Remote Control
Sky on AV1 no picture
Contact any service technician or refer its user manual for details. Electro help
Nov 03, 2014 | Panasonic CT-32SL14 32" TV
Switching av1 av2
If the TV is not working well and you don't want to take it in for repair, then a band aide would be to get a sound bar ~$50 and use that for sound. You may have to get an AV selector box if you have more than one playback unit.
Oct 31, 2013 | Vizio Televison & Video
Can't find AV1 on menu
You can Convert the DVD to Video OR Convert DVD to Flash,play on PC.
http://www.powerpoint-video-converter.com/
Nov 20, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Do you know how to get sound back on when you switch to av1 picture fine but no sound thanks
Make sure that you have the audio input hooked up to the correct input (AV1). For the AV1 channel there should be either RCA (yellow, red, and white) or S-Video (generally a black plug) plus the red, and white from the RCA. Make sure the red and the white are both connected to the AV1 Input. Hopefully this solves your problem.
Thank you
Feb 28, 2011 | Sony Televison & Video
Can I hook my pc to my sound system
Your cable must be a minijack to 2RCA. Minijack connected at line out on computer and 2RCA at AV1 in or other available port in on HHTS(Home theatre) (white and red socket). That is sound only. Video will be yellow (or vga/DVI/HDMI depending on graphic card)from your graphic card to AV1 in. same port as sound. Now select AV1 on HTS. If no picture on tv make sure you computer graphic card is set for dual display .
Aug 29, 2009 | Panasonic Home Theater System System
Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Jul 10, 2009 | Philips 32PW6506 32" TV
Im trying to hook up my new lcd tv using a cable box and a dvd player but cant find any diagrams. As of now I can get a picture but the sound is low and can only be turned up by the cable remote. Any help...
it should not be a big deal red and white is sound yellow is video, if you have a converter box and are not getting a signal I would suggest you try moving your antene to get picture. Try hooking the DVD plaer into the TV to AUX 1 or AV1 or AV 2 Or AV3 and make sure the TV is on the right channel on to see Picture and correct level of sound, are you running anything threw a coverter box? Need to know the TV brand to do a diagram. The output from the DVD player shoud go into AV1 and the wire colors should be the same DVD output to AV1 input or AV2 in?
Jul 06, 2009 | Televison & Video
Sound but no picture on PS3 using AV3/4
the best configuration is using component AudioVideo cable.component video out from ps3 use 3 wires going to component video input to your tv (Y-Pb-Pr) and two wires for audio left.right. use av1 input on your tv to hook the audio and video. let me know if you still have issue.
Apr 05, 2009 | Philips Televison & Video
Can't get sound when used as computer monitor
comp sound Tv
Your cable must be a minijack to 2RCA. Minijack connected at line out on computer and 2RCA at AV1 in or other available port in on TV (white and red socket). That is sound only. Video will be yellow (or vga/DVI/HDMI depending on graphic card)from your graphic card to AV1 in. same port as sound. Now select AV1 on tv. If no picture on tv make sure you computer graphic card is set for dual display .
Feb 02, 2009 | TruTech PM1919BXA1 19 in. LCD TV
AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Nov 26, 2007 | LG 32LX3DC 32 in. LCD HDTV
Toshiba Se-r0301 Q152 Remote Control Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
