Question about JVC GR Video Cameras
How to repair the recorder focus
May hinge on cleaning the lens, if so do I remove them from their housing ?
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: I have a Mitsubishi SL2U
If the focus lens is meant to be taken off from the front, it can be unscrewed, howevery I believe you will have to take another approach.
I tried to take one of these apart one time, and all I could figure out was that I had to take the whole lens piece off, and get to the lenses from the rear of the assembly, so to speak.
Here is the manual:
http://www.docstoc.com/docs/5901142/Mitsubishi-SL2U-Users-Manual
Wish I had a diagram, but hope this will help.
Posted on Oct 01, 2010
How to repair or unstick Sigma K zoom 100-200mm macro - tele focus stuck at infinity
Remove the lens from the camera, set MF on the lens, try gently to free it by hand. If this works, clean the contacts on the lens and camera body - if not, it needs repair.
Jun 05, 2017 | Canon Cameras
Hi. My video is a JVC GR-D73U. When I turn the video camera on and try to record, the focus works continuously, trying to get a clear image. It does not succeed so the record is very hazy. I forgot to...
The most likely cause for this is a zoom or focus lens out of place or impaired in some way. This will require disassembling the camera to remove the lens assembly and then disassembling the lens block to repair. This can be done fairly inexpensively but it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 23, 2011 | JVC GR-D73E Mini DV Digital Camcorder
I had dust inside my camara and I cleaned the internal glass, ( the part that has the focus circle, not the mirror,) with lens solution and a lens tissue, it appears to have removed what might have been a...
First off, that is the focusing screen and you have to learn: NEVER USE ANYTHING BUT A BLOWER AND A CAMEL HAIRS BRUSH TO CLEAN IT. REpair/replacement by a camera repair shop is authorized.
Dec 12, 2010 | Pentax ME Super 35mm SLR Camera
Error 99 and jerky fixation of focus between 17 and approxinately 30 mm works perfectly at zoom lengths beyond this with normal rapid fix of focus and records image normally. the error and failure to...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
For the jerky focusing ring, you need to get the lens serviced by an authorized service center.
Aug 28, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Have a canon IXY with a lens retracting issue, also does not focus. states to restart camera.
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either problem will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 15, 2009 | Canon Cameras
My camera will not auto focus properly...It will focus and refocus. I have to use the manual focus in order to use it.. I have already checked it was in AF setting both on the camera and the actual lens. I...
Try removing any filters, if you have any on the lens. Check the front and rear lens elements for dust/fingerprints and clean if necessary. Check the mirror (remove lens and take a look) and very carefully clean if dirty. Remove the lens and gently clean the gold contacts on the back of the lens and in the lens opening of the body with a pencil eraser. Don't let the bits fall inside the body. Try the focus outdoors in good light of a scene with lots of clutter in the frame to see if the problem only occurs in low light. Check the menus and make sure the focus assist lamp is in the on position. Let me know if these solve your problems.
Sep 26, 2009 | Nikon D80 Digital Camera
Hi, my Samsung nv10 camera, when switching on, only the auto focus light comes on. The lens does not pop out or open. The only way to switch off the aoto focus light is then to remove the battery. Any...
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Samsung NV10 Digital Camera
My Nikon D40 18-55mm lens won't work on automatic
THERE is a problem in lens not with the UV filter
remove the lens clean the contact of lens & camera if not working repair or replace it
Jul 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Recording
Both previous suggestions are wrong. Your machine displays 'wrong disc' as you are trying to use a computer grade CDR, this machine needs a 'consumer audio' grade cdr that are more expensive. Google the manual, it explains further.
Nov 09, 2007 | Philips CDR930 CD Recorder
Video Cameras Logo
50 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
