Question about Keurig B60 Coffee Maker
Why does my Keurig coffee pour out all over the place?
5 Suggested Answers
  • 460 Answers
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
Posted on Nov 12, 2009
SOURCE: When we put the coffee
Hitting the brewer might cause other problems. My brewer would make the correct noises but no water would come out into the K cup. Like other posts say, unbend a large paper clip and carefully slide the end up into the opening where the water comes out (and apparently coffee grounds get caught in). If you don't go to the first bend, you may not get the clog cleared entirely but it will put your fingers close to that very sharp needle so be careful. It took a couple tries for me, to get it right. It's been fine for two weeks so far.
Posted on Aug 01, 2010
heatman101
  • 43501 Answers
SOURCE: keurig coffee maker pours water back into tank
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Feb 26, 2011
heatman101
  • 43501 Answers
SOURCE: my keurig machine will not
heatman101
Posted on Mar 01, 2011
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    My Keurig coffee maker will makes a grinding sound when the start button is pushed, the K-cup is in place, but water does not pour through into the cup.
    Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
    Keurig CoffeeBrewer not making a full cup of Coffee
    heatman101
    May 07, 2011 | Microwave Ovens
    My keurig machine will not pour coffee out. it says its ready and yo can hear the water inside. what do i do
    heatman101
    Feb 08, 2011 | Keurig B50 Coffee Maker
    Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
    heatman101
    Feb 02, 2011 | Keurig B70 Coffee Maker
    Keurig coffee maker pours water back into tank rather than into cup
    heatman101
    Jan 12, 2011 | Keurig B60 Coffee Maker
    The coffemaker won't brew and showed a descale message. What does that mean?
    Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
    1.Unplug the coffee machine and remove the cup.
    2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    6.Unplug the machine and dump the water into the sink.
    7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
    Dec 10, 2010 | Keurig B70 Coffee Maker
    De Scaling instructions
    Also, if you have an in sink garbage disposal, don't waste the hot vinegar.  Pour it into the disposal, turning the unit on as you pour, off when you're done.  The vinegar is mildly acidic and will disinfect the disposal unit.
    Feb 17, 2009 | Keurig B60 Coffee Maker
    Keurig B60 Coffee Maker Logo
    191 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Oloyede Monsuru
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
