Question about Garden
How do i replace the heighth adjustment lever on it... rear wheel drive
  • 1,602 Answers
How to ajust trottle linkage on transmission
Throttle valve cable adjustment:Place throttle body in idle position. Press cable lock button to release cable. Pull cable conduit toward rear of vehicle until wiper is completely retracted into end of conduit fitting. Release cable lock button. Raise vehicle for access to trans throttle valve lever. Rotate throttle valve lever toward front of vehicle until ratcheting sound (from cable) stops. CAUTION " Do not rotate throttle valve beyond the idle stop. The lever, valve and manual lever shaft will be damaged if rotated too far." Check cable adjustment. Throttle valve lever should begin to move at same time lever on MPI throttle body moves off idle position. Lower vehicle. 1991/1992 Rear Wheel Drive Truck There is also an adjustment procedure for front and rear band adjustments at engine if you need them.
Jul 27, 2014 | 1992 Dodge Dakota
Handbrake doesn't hold
handbrake wont hold due to incorrect adjustment method .
Under handbrake lever cover there is a thread rod with a 10mm nut on it undo it until the nut is level the top of the rod.
2.remove rear wheels
3.remove brake capliers and brackets
4.remove rear disc rotors.
5.get some sand paper and clean handbrake shoes and inside of disc rotors.
6.use a and adjusting tool and adjust the handbrake mechanism until you can feel drag on the rortor.
7.refit brake brackets and capliers
8.refit wheels
9.lower vehicle
10.now the vehicle is on the ground at the hbrake lever use a 10mm socket to adjust rod.
11.adjust the lever so its 7clicks .
12.on lever ground place the vehicle in drive apply hbrake 7clicks and it should hold vehicle..
Feb 26, 2014 | 1998 Holden VT Commodore
Need to know how to operate the adjustment knob for the cutting heighth on the deck lift component on a Craftsman MV18S - 58560 riding mower
that model # is for the engine
the knob should screw in or out
pull deck lever up screw knob either in or out release deck lever
Apr 29, 2013 | Craftsman Garden
Adjust handbrake 94 libero
  • Remove the center console covering the parking brake lever. Locate the parking brake lever between the drivers seat and the front passenger seat. Put the parking brake lever in the lowest position.
  • 2
    Turn the cable adjuster locknut to make the nut loose. Find the nut at the base of the parking brake lever.
  • 3
    Raise your GT rear wheels using a jack and support the rear wheels using jack stands. Remove both rear wheels using a tire iron to loosen and take off the lug nuts. Take off the tire from the rods by hand.
  • 4
    Get underneath the car and remove the rubber hole plugs from the brake rotors. Locate the rotors on the underneath inside of the wheel wells.
  • 5
    Take off the brake calipers with a screwdriver, but do not disconnect the brake fluid lines.
  • 6
    Use a pry bar to push up on the parking brake self adjuster wheel. Locate this next to the brake caliper and it looks like a star wheel. Rotate this wheel until the rotors will not turn.
  • 7
    Turn the adjuster wheel five notches in the opposite direction. Reinstall the calipers and wheels. Lower your GT using the jack and remove the jack stands from the rear wheels.
  • Sep 13, 2012 | Mitsubishi Cars & Trucks
    Front wheels on manual mower lock when pushing for awhile.
    1 Locate the height adjustment lever on the inside of the left rear wheel.
    2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
    Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
    3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
    4 Release the lever over the locking pin closest to the desired height of cut.
    5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
    Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    This ZR4625 is new. It will not track straight. With both levers forward it tracks to the left, I can pull back on the right lever and it tracks ok but it slows down a little. What do you adjust?
    First check both rear tyre pressures, if ok you need to adjust the rod that runs between the left lever and the hydrostatic drive on the left rear wheel so that the short lever on the hydrostatic drive travels further when push the drive lever forward. Regards Phil
    Apr 14, 2011 | Husqvarna Zero Turn Mower Z5426
    Autohelm 4000 ST fails to drive
    CHECK INSIDE
    BELT CONDITION
    RUNNER BROKEN OFF
    CHECK OUTSIDE
    CLUTCH LEVER PIN BROKEN ,CLUCH LEVER OUT OF POSITION
    BELT TENSION ADJUSTMENT WRONG (REMOVE SMALL COVER PLATE (+- 10mm Dia)ON REAR OF BACKPLATE ,LOOSE SPECIAL NUT ADJUST WITH ALLEN ,TORQUE NUT,PUT COVER BACK
    Feb 19, 2010 | Raymarine St 4000 Wheel Drive E12093
    1999 nissan quest rear brake shoes need changing
    help is here:
    http://autos.groups.yahoo.com/group/villagerquest/
    Drum Removal
    1. Remove the rear wheel and the tire assembly. Refer to Section 204-04 .
    1. Retract the brake shoes and loosen the brake adjuster screw.
    1. Remove the brake drum.
    May require big hammer to loosen drum from axle flange. Hit between the the lugs, not on them.
    #10 is access plug to back off adjusting wheel.
    Item Part Number Description 1 2261 Rear wheel cylinder 2 — Dust boot (part of 2128) 3 2197 Wheel cylinder piston (part of 2261) 4 — Cup (part of 2128) 5 2204 Wheel cylinder piston cup spring (part of 2128) 6 — Wheel cylinder housing (part of 2261) 7 — Brake shoe hold-down pin 8 — Access hole (part of 2212) 9 — Rear brake bleeder screw (part of 2261) 10 — Access hole plug 11 — Rear wheel cylinder bolt 12 2212 Rear brake backing plate 13 — Rear brake backing plate bolts 14 2N790 Parking brake lever clip 15 — Spring washer 16 — Secondary brake shoe and lining (part of 2200) 17 — Brake shoe hold-down spring (part of 2B514) 18 — Lower retracting spring (part of 2B514) 19 2A637 Parking brake lever 20 — Parking brake lever pin 21 2A177 Brake shoe adjusting lever 22 — Adjuster lever pin (part of 2A177) 23 — Primary brake shoe and lining (part of 2200) 24 — Upper retracting spring (part of 2B514) 25 2041 Brake adjuster screw
    Shoes Removal
    Take a picture and remember how each part goes and attaches
    1. Remove the brake drum, refer to Drum in this section.
    1. Remove the upper retracting spring.
    1. Remove the lower retracting spring.
    1. Remove the self-adjuster.
    1. Remove the hold-down springs.
    1. Remove the parking brake lever clip and the parking brake lever.
    Apr 17, 2009 | 1999 Nissan Quest
    I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
    Drum, Rear Brake System Standard Rear Brake
    Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
    Heavy Duty Rear Brake
    Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
    The rear drum brakes:
    • Have internal shoes that expand against the brake drum (1126).
    • Are a single-anchor type.
    • Are actuated by one rear wheel cylinder (2262).
    • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
    • Adjust rear brake shoes and linings (2200) automatically.
    • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
    When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
    The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
    Apr 04, 2009 | 1997 Ford F150 Regular Cab
    Garden Logo
    94 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
