Question about Health & Beauty
I have a jazzy 610. There are 8 lights flashing. No pause. Just fast flashing. What does this mean?
    Top Expert:
  • 1,144 Answers
"A controller system fault is indicated. Make sure that all connections are secure."
(Owners Manual - Page 35).
http://www.scootaround.com/files/manuals/pridemobility/Pride%20Jazzy%20610%20Owner's%20Manual.pdf
Posted on Apr 21, 2015
  • Shaun Berry
    Shaun Berry Apr 21, 2015
    I have plugged and unpluged. Everything. Tightened battery terminals. Anyother ideas? When I unplug the joystick from the circuit board. The lights go out. And one amber light comes on on the row under the main battery light bar.
  • Ngoro
    Ngoro Apr 21, 2015
    Probably controller system fault. Contact your authorized Pride Provider.
4 Suggested Answers
  • 175 Answers
SOURCE: looking for a weather cover for my Pride Jazzy 610
A good substitute, and cheaper than buying it from Pride is to go to WalMart, etc and get a cover for a bbq grill.
Posted on Jul 11, 2009
HoverTech
  • 232 Answers
SOURCE: jazzy 610 got wet. controller lights blink
Electricity and water don't mix. Allow the controller to dry out for several days. Even if it looks dry, water may have collected inside and fried something.
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
  • 4 Answers
SOURCE: jazzy 1107 power wont move. Lights are 2 red, 4 yellow and 4 green. Flashes 3 times then pause. This continues.
Used to service those things before I retired. If I remember correctly, a "3" flash indicates a brake problem. Make sure brake is engaged on both sides. You can also call Pride Healthcare at 1-800-800-8586.
Posted on Jun 14, 2013
Testimonial: "I have engaged and disengaged the brakes many times with alot of force. Unplugged wires and cleaned. I will call Pride with the number you provided. Thanks for your help."
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
Lights on controller flashing
You can get the service manual from Pride's website. It will tell you what the flashes mean and how to fix it.
Apr 08, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy model 1103 - one speed and speed light flashes
hi,when the speed light flashes,is there a pause or is this a continous flash ?regarding missing a connection, that i very much doubt...
Regards
Rob
www.gewizrepairs.co.uk
Dec 12, 2013 | Pride Jazzy Select 6
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Won't move lights are flashing on the controller batteries are fully charged any help
Doug I need to know how the lights are flashing ie 4 times pause 4 times pause etc or are all the lights flashing slowly or are the lights scrolling from left to right or right to left Thanks
Apr 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
I have a jazzy 1121 power chair and the lights on the joy stik are flashing and the chair just stoped working
Doggy count the number of flashes ie 4 flashes pause 4 flashes if you are not getting any pauses
what lights are flashing the battery level lights or the speed lights? Are all the battery level lights flashing or there are 3,4,5,6 or 7 etc. lights flashing? if you are getting a pause between flashes the number of flashes will tell you the error. Your owners manual should tell what each code means. Hope this helps
Mar 06, 2011 | Health & Beauty
My hand controler on my jazzy 1120 2000 keeps blink and I can not get the chair to move the batteries are good
GAdams You need to count the number of flashes. The number of flashes will give you the flash code or error code. IE: 3 flashes pause 3 flashes pause etc. = left motor short If you have your owners manual it should list the flash codes and what they mean for your chair. If not you can contact Pride Mobility @ 1-800-800-8586 and ask for Tech Support. If medicare paid for your chair the they will pay most of the repair cost. Contact the provider where you got your chair to see if they can repair it or refer you to a service Company that can. Hope this helps
Oct 05, 2010 | Pride Mobility Products Used Jazzy...
My jazzy select 14 keeps lighting up like its charging after its unpluged and the chair wont do anything
Can you tell if the lights are flashing a number of times then pausing slightly then flashing the same number again and so on? If not then check to make sure your not in "freewheel". The levers are behind each wheel If you are getting a flash code determine the number of flashes the codes should be in your user manual or goto Pridemobility.com and you can download a owners manual for that chair. Hope this helps
Aug 22, 2010 | Pride Mobility Products Jazzy Select 14 XL...
My jazzy 1115 joystick controller flashing and the chair doesnot move .
1. make sure it's not still pluged in recharging.
2. make sure both free wheel levers are engaged.
if the jazzy is still flashing and not moving refer to the flash code in your owners manual. count the flashes between pauses. get back to me if you don't have the manual. Mike
smithrm70@hotmail.com
Nov 20, 2009 | Electric Jazzy 1115 Power Wheelchair
Health & Beauty Logo
210 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
