Question about Frigidaire Dryers
My frigidaire infinity dryer after 5 minute the cycle stop.
Each time I start the cycle stop after 5 minute. No matter the cycle, the inscription is ADD and upper light of the start button flash quickly. I push the cancel and the select button in the same time for 6 second and I have description code rE5. So wath is the problem?
  • Frigidaire Master
  • 2,760 Answers
ADD= automatic dry detector this would explain why it stops after 5 min , must be a fault with that
ive had to clean them off inside the drum many times with glass cleaner (nothing stinky) or it will transfer to clothes
mounted just under the lint trap is two shiny steel bars , or some models it's in the back near the center softener sheets come off and coat them up
Posted on Apr 21, 2015
Why wont my frigidaire dryer shut off when done
Good Afternoon Arlene,
I understand your Frigidaire dryer will not shut off when the time is done. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave the model number of your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Electric Dryer
Dryer will run but will not heat and the lights all flash
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# GLEQ2152ES, will run for a few minutes and then stop and display "AD" with the lights flashing. The "AD" means that your appliance was in an automatic dry mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire GLEQ2152ES Electric Dryer
How to fix frigidiaire dryer error code 61
I understand you are receiving an E61 error code on your Frigidaire dryer and want to know how to fix it. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire Electric Dryer
My frigidair affinity dryer wont start it just beeps
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
Frigidaire dryer duzzes when start button pressed or starts but stoppes after a few minutes
I understand that your Frigidaire dryer, model# FDE336RES0, buzzes when the start button is pressed. I also see that it starts then stops after a few minutes. I suggest checking the cycle selector and making sure that it is not loose or has not come off. If this is not the case, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Frigidaire Electric Dryer
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
I had a bunch of verywet towels because my sink was leaking, and I put them in the dryer and it worked for a few minutes them stopped. What might be wrong?
Good Morning Friend,
I understand that you had a bunch of wet towels, and put them in your Frigidaire dryer, model# FGQ332ES. I see that your dryer worked for a few minutes and then stopped. There could be a possibility that the wet towels were too heavy from all the water in them. I suggest that you spin the towels out in your washer first and then move them over to your dryer. If you are still noticing the dryer working for a couple of minutes and then stopping, I suggest giving your appliance a hard reset. You will do this by either unplugging your appliance or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored start it on any cycle. If your dryer is still shutting off after a few minutes, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off after a few minutes. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire FGQ332ES Gas Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Frigidaire Gallery Dryer Needs Two Cycles to Dry Clothes
A dryer needs to exhaust properly in order to dry no matter where it's situated. Insure that the venting is not crushed at the back and that it has a good strong air flow outside
Jun 21, 2009 | Dryers
Dryers Logo
198 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
