Question about Toro Garden
I have a Toro LX 500 Lawn tractor the pto clutch will not engage, I have 13 volt at the plug for the clutch , so ordered and installed new clutch... Still will not engage checked volts again had 9.3
Not sure if it could be the pto switch or ignition switch or in one of the safety switches.. Can you please help me with this problem ???
  • Toro Master
  • 1,169 Answers
Load test the PTO circuit as it may a connection that allows you to a voltage reading when unload and then once loaded drops out.
By load testing I mean leave the PTO clutch coil attached and test while it should be engaged.
Posted on Apr 22, 2015
    Sergeant:
  • 187 Answers
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
4 Suggested Answers
  • 6468 Answers
SOURCE: 325 lawn tractor,pto will not engage.clutch is ok and new switch installed. No 12 v to cluch when sw is engaged.
what switch did you replace the one that turns it on or the safety switches in the middle of the circuit?
Posted on Apr 13, 2012
radco855
  • 126 Answers
SOURCE: Can malfunction of PTO or other safety switches prevent start up of mower
You didn't state the model or brand of tractor, but usually the way the cranking circuit work is, from the "S" terminal of the ignition switch, the circuit runs to the PTO switch, if it's in the OFF position, the circuit then runs to the pedal switch, if it's in the DOWN (or brake on) position it then runs to the solenoid. On other tractors, from the ignition switch, the circuit runs to the pedal switch first. (The seat switch isn't used in the cranking circuit).
Any switch can go bad, but I would more likely suspect the pedal switch or loose connection at either switch. (But it could actually be the PTO switch).
Try tracing the circuit from the "S" terminal of the ignition switch through the PTO or pedal switches to the starter solenoid. You may get lucky and find something obvious.
If you find nothing, try jumping across the pedal or the PTO switch (only two terminals are used in the cranking circuit, trace back to ignition switch for the incoming, outgoing is usually directly adjacent). Jumpering will take these out of the circuit and tell you if either is bad internally.
Lastly, there's always the possibility that the ignition switch is bad. (Doesn't happen all that often, but it's suspect as well). Jumper from "B" terminal to "S" terminal will take it out of the circuit.
Posted on Aug 22, 2012
SOURCE: electric PTO does not engage on garden tractor
Its a torro Timecutter z4202
Posted on Nov 17, 2014
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Craftman lawn tractor 20.0 HP 42" electric start blades will not engage
Check for voltage at the electric pto clutch connector if 12 +volts is there when the switch is on then the clutch is bad; otherwise, you need back through the wiring to find the problem.
Aug 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
New pto clutch willnot engage gets hot
First off I would check for power and ground at the connector. Not knowing what kind of unit you have I have to go with the most common, or what I see the most of.. The PTO switches are bad to short out on some models and can cause all kinds of issues. I hope this is not a case of replacing the clutch when the switch was the problem.. Good luck..
Apr 13, 2014 | Toro Garden
Toro repair manuals
I have this same problem on my 36 in toro pro line sfs i ohmed the clutch the wire the safety switches and the PTO engagement switch all checked out good if u find any thing let me know the clutch its a adjustable clutch and its supposed to be set at .018 at all three springs there will b a slot that's where u check that but. U can get a multimeter and test the clutch by putting it on ohms and hooking up on both sided of the plug once u have unplugged it.the clutch should ohm out at like .003 or .004 max if more the clutch is shorted out
May 07, 2013 | Toro 52" Cut Wide Area Walk Behind Lawn...
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
Toro riding lawn mower pto switch not engaging to turn blades
see if you have power and ground to the connector that goes to the clutch it could be a bad safety switch
May 21, 2012 | Toro Garden
Pto switch not engaging propellars
check for power and ground to the connector that goes to the clutch this will tell you if it the clutch or safety switches and or wiring
May 21, 2012 | Garden
PTO will not engage on my 0 turn Cub Cadet RZT 50. What should I check and how do I check it?
see if the switch is getting power to it and if it is see if the clutch is getting power. it needs 12 volts in order to engage.
Feb 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
My electric PTO on my Husqvarna Model YTH180 does not engage
I'm having same problem. I think it's the switch, Running the system reads 14.6 volts. pull the switch No power to the lead that goes to PTO. if I jump 12v to the clutch the PTO engages fine. also changed the relay. Just wondering if there may be some other safety switch I may be missing? Hopefully it's just the switch. I dont know the likelyhood of those going bad the mower has tractor has 500 hours on it and looks damn near new.
May 31, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
278 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
