Question about Building Materials
On 4 occasions we found the door open! Installed in November 2014!
315MHz security with keyless entry!
    New Friend:
  • 130 Answers
Try changing erasing and programing new codes.. If that doesn't work, try moving the wires to your wall switch and see if that makes your door move.
Posted on Apr 27, 2015
  • 2,374 Answers
Sometimes the down force is set too light and the door opens as it gets to end of travel. Are you sure it was closed and stopped when you found it opened? Or just heading down as u drove off. Also, the wall remote if wired could have a staple that penetrated the wiring, that shorts out and opens door intermittently.
Posted on Apr 22, 2015
Need to change fuse on remote keyless entry but don't where it's located on fuse box on 2004 explorer
Do any doors lock/unlock with remote keyless entry ?
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter battery.
  • Remote transmitter.
  • Remote transmitter programming.
  • Aftermarket system.
  • High power devices.
  • TV/radio transmission towers.
  • Vehicle security module.
  • Go To Pinpoint Test C .
Pinpoint Test C: The Doors Do Not Lock/Unlock Using The Remote Transmitter
Normal Operation
Remote locking and unlocking of the doors is accomplished by the vehicle security module receiving a command message from the remote transmitter. The vehicle security module processes the command and sends a signal directly to the door lock actuators.
All remote transmitters must be present to begin diagnosis of the remote keyless entry (RKE) system.
Aftermarket or dealer-installed systems may adversely effect the RKE system operation. These systems should be disconnected before diagnosing any RKE concerns.
Visual Inspection Chart Mechanical Electrical
  • Latches
  • Battery junction box (BJB) fuse(s):
    • 2 (30A)
    • 16 (15A)
    • 22 (20A)
    • 29 (60A)
  • Central junction box (CJB) fuse 20 (5A)
  • Circuitry
  • Relays
  • Keyless entry keypad
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
  • Check that the program card is correctly installed.
  • Check the connections to the vehicle.
  • Check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • SCP+, SCP- OR UBP circuits fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for vehicle security module, refer to Section 418-00 .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the vehicle security module.
  1. If the DTCs retrieved are related to the concern, go to the Vehicle Security Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If DTCs are retrieved that are not found in the following Vehicle Security Module Diagnostic Trouble Code (DTC) Index, refer to the Master Vehicle Security Module Diagnostic Trouble Code (DTC) Index in Section 418-00 .
  1. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Nov 18, 2015 | Cars & Trucks
Bought from dealer with no keyless entry. alarm activates when doors are locked with power doorlock system. alarm sounds when we open the door. how do we de-activate the alarm before unlocking the door?
Opening the drivers door with the key is supposed to shut down the factory security but the drivers key cylinder usually goes bad. You will have to unlock the rear tail gate lock cylinder with the key and that will shut down the factory security, before opening the drivers door.Your other option is to have an aftermarket keyless entry system installed, which will open the doors remotely while shut down the factory security at the same time.
Jan 25, 2011 | 1996 Jeep Grand Cherokee
My lift master security plus keyless entry pad for the garage door no longer will open the garage door when I key in the four digit code. Can I reprogram the entry pad and if sohow?thank you
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
94 nissan altima GXE keyless option
Any vehicle can have keyless entry installed as long as the car has power door locks.I would recommend the viper aftermarket keyless entry. It works very well.
May 14, 2009 | DEI Python 1400XP Remote Start/Keyless...
Keyless Entry Problem
First try changing the battery in thh keypad 9V. if that dos not work just moving the wire coming from your opener towards your keypad. DONT CUT THE WIRE OR ADD TO IT. That should take care of it
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming my keyless entry
Yes, you purchased the wrong wireless. You must get a Genie keyless and there are two types of Genie keyless (GWKP & GWK-BL) depending on which Genie operator you have. You might think about a wired keyless entry (Domino GD-1). Then if you change your operator you don't have to change your keyless.
Nov 09, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Keyless entry pad for garage door opener
THE FREQUENCY OF THE UNITS ARE PROBABLY NOT COMPATABLE THEY CHANGED ABOUT 2 YEARS AGO.
SORRY - I THINK YOU NEED A NEW KEYPAD TO GO WITH THE NEW OPENER.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
187 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
