Question about Dishwashers
Fills up with water ,draining well but sprayer arms don't work or not washing dishes.
  • 641 Answers
SOURCE: No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
Posted on Jun 20, 2006
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
SOURCE: frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Posted on Jan 31, 2009
  • 677 Answers
SOURCE: Whirlpool Gold Dishwasher "Quiet Partner' Fills But Won't Wash
www.dishwasherfilter.com will fix your problem. its your water and not the dishwasher.
Posted on Jul 17, 2009
BIKER T
  • 909 Answers
SOURCE: Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Posted on Sep 18, 2009
Water fills the bottom of dishwasher, lower spray arm still seems to turn/spray but no movement or water coming out of uppoer spray arm. We took apart the lines to see if there was blockage -- none.
If there is no blockage, your pump may need to be rebuilt or replaced. If your machine uses a solenoid valve to control weather the pump is washing or draining. The drain valve may be stuck somewhat open, diverting wash water down the drain. Or the wash valve may be not opening fully. Different machines work in different ways.
Nov 09, 2013 | Dishwashers
Dishwasher fills up, but doesn't spray.
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 02, 2010 | Dishwashers
Dishwasher comes on, fills with water, water heats, no movement of the arms so no water spraying out, then the water drains, it goes through the dry cycle and no clean dishes.
What is the manufacturer and model number of your dishwasher?
Depending on the model and design, the sprayer motor/pump has probably failed and the drain motor/pump is still working.
Recommend you pull the sprayer arm and filter. Look for debris that could be jamming the pump - watch out for broken glass when looking.
Make sure the impeller can spin and is not damaged.
If that does not fix the problem, replace the wash motor / pump or replace the entire dishwasher with an Energy Star qualified name brand model.
Good Luck!
Apr 01, 2009 | Maytag 24 in. MDB5600A Jetclean II...
The dishwasher fills up with water but will not spray water.
This is a comen problem here is how to solve it and prvent it in the future.
First you need to remove the wash arms top and bottom then look and you will see a few ole in the arms both sides these are more than likely blocked with small bits of food clean the hpoles and rinse the arms make sure all the holes are open and replace the arms.If this is the case in future scrape the plates off in the bin and rinse any loose food off in the sink before washing the dishes in the washer,give this a try and let me know how it went.
Feb 01, 2009 | Asko D1876 Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Fills with water but won't wash.
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Aug 11, 2007 | Maytag 24 in. MDBH950AW Built-in...
Dishwasher not washing
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
