Question about Poulan Garden
I have a Poulan pro 300ex that chokes out everytime you throttle up I've cleaned the Carb and don't know what else to do please help
  • Poulan Master
  • 2,760 Answers
Fuel starvation at high speed is most allways a filter/hose problem sometimes it can be a problem on the high speed jets in carb ,but post 2010 models are c.a.r.b. compliant and the jets are sealed from ever getting them out to clean them , new walbro carbs are only about fifty/sixty bucks online
have you tried car fuel cleaner ?
Posted on May 20, 2015
cj2176
  • 520 Answers
SOURCE: the saw wont stay running. I start it with full
Sounds like the carb needs to be rebuilt. Those tiny jets will clog easily and need to be replaced. The diaphragm is also a large part of bogging and dieing. Hope this helps.
Posted on Jun 14, 2009
dontbother10
  • 2220 Answers
SOURCE: i have an echo chainsaw cs 346 it starts fine revs
Try rotating the "H" adjustment CCW a small amount.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Posted on Jan 11, 2010
dontbother10
  • 2220 Answers
SOURCE: Poulan PP446T Pole Saw. Will run only if choke is
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Posted on Jan 23, 2010
  • 4088 Answers
SOURCE: poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Posted on Feb 24, 2010
nedkelly900
  • 345 Answers
SOURCE: carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Posted on Apr 28, 2010
I have a 350 poulan pro ordered a carb. installed new filter line and primer bulk. It will start and run as long as I have the choke on. As soon as I move the lever for the choke I boggs down. Gan anyone...
Hi dennis
Sounds like to me that you have a problem with the high speed circuit of the carb...could be some trash in the jet or the jet may be out of adjustment...try adjusting the jet and try to go to full throttle after your adjustment
Apr 14, 2013 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan pro honda engine stalls as auto choke lever moves
Hi, when you say you cleaned the carb, did you strip it down and blow all the jets out with compressed air? If so, check that you have fuel flowing into the carb. If all this is ok check the valve clearances. Regards Phil.
Jun 24, 2012 | Poulan Garden
it sounds to me that there s a jet inside the carb that is still plugged
Jun 24, 2012 | Poulan Pro " Pro" Self Propelled Mower
Poulan pro 300ex riding lawn mower
pull the top cover and see if the starter gear broke if so napa has them for about $10
May 06, 2012 | Garden
Won't start
I have a poulan pro 295. Can't get it to fire. I've replaced the plug, and ignition coil. cleaned the entire chainsaw.
Nov 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weedeater will not run with choke open.
check your air filter,, and try if do the same thing you have to clean carb. out,, if you dont how just ask me,, thanks hope this help you
Sep 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Lawntractor 13.5HP throttle linkage missing
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
Jul 03, 2009 | Oregon Scientific Oregon Fusion Blade For...
Garden Logo
131 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
