Question about Muratec F-520 Fax Machine Copier Black & White Printer
Makes loud clicking noise when printing - Muratec F-520 Fax Machine Copier Black & White Printer
Canon Pixma MP780 makes a loud clicking noise. No paper jammed anywhere. It seems to be the gears where the cartridges are.
i have th same exact problem, just took much of it apart, bu still cant see why it makes the loud noise, also I cant switch paper feed to back, which at least would allow it to print from there... please let me know if you find a solution.
Nov 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
HP photosmart C3180 makes a loud clicking noise when printing first page.
After inserting new cartridges in the photosmart C3180 and closing the door it makes loud clicking sound coming from the cartridge area and won't print.
Nov 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Oct 19, 2009 | Samsung CLP 300 Laser Printer
Won't print. makes loud clicking noise from right side front of unit (ink cartridge parking area)
Please have a look at the noise troubleshooter available for your printer at the HP online support site. Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | Office Equipment & Supplies
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Brother mfc8440 clicking sounds while printing
I had the same problem when I used a refurb toner cartridge, had to replace cartridge with oem for it to print. After a while started making same noise, had to take it in to have parts replaced. Now I don't take any chances on non-oem parts, it's not worth it.
Mar 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Muratec F-520 Fax Machine Copier Black & White Printer Logo
64 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
