Question about Tablets & eReaders
Will not display although battery is fully charged. If it is a motherboard problem, can it be fixed? This is not name brand but good Android tablet.
SOURCE: kaser Android tablet will not turn on or charge its brand new
Did you drain the battery completely and try to recharge it? A lot of people have problems if they drain the battery and recharge. I went through 3 A300 tablets before I figured out I had to recharge the tablet BEFORE it went dead or it would never start again. I don't know why but many brands have this problem. Also, do not shut it completely off when it is on the charger. Always take it off charge, or turn off before charging. I had another prestige that had to be replaced because I turned it off or on while charging. I have not found out why this happens to many tablets! Good luck!
Posted on Feb 26, 2013
  • 22 Answers
SOURCE: Coby Kryos Android Tablet
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
Posted on May 21, 2013
  • 135 Answers
SOURCE: Kocaso m766 android tablet micro usb port not
first verify that the charger isn't dead
try connecting this charger to another device to see if it's functional
Posted on Apr 21, 2014
lawrencem420
  • 9 Answers
SOURCE: Battery will charge to 100% only 50%
Its probably because of your tablets power source. If you have used your tablet very often then it will begin to cause the battery to drain more quickly and it will also not fully charge. It could also be a problem with your charger. There could be a short in it or something else that would cause it to stop charging the device at a certain point. The tablet isn't powered by a removable battery so don't try to open up the back and tear out any circuit that you think is the battery as this may cause even more damage to your tablet. If you have a warranty on the device then try taking it to the store you bought it from and see if they can help, but if you don't then be prepared to spend some cash. You could also take it to a tech store (if you know of one) and maybe they could run a diagnostic on the tablet to see what's wrong. If you're trying to charge your tablet while its turned on it could also be the amount of apps that you have installed on your device. Apps can actually cause put a strain on the battery and cause it to preform poorly. Try to avoid large apps (apps that take up a lot of space) because they can actually cause the device to run slower and it will also force more power to be drained from the battery which in turn will keep the battery from charging fully while its on. Try either one to see which one works for your device.
Posted on Jan 07, 2015
kingbenny101
  • 18 Answers
SOURCE: I have a android jellybean 4.2 tablet when you put
This could be caused by the power button sticking, you can try removing the back cover and see if this is the problem. If not you could try accessing boot loader menu by holding power and volume down - go to recovery and do a hard reset.
Posted on Mar 23, 2015
My tablet will not turn on after charging it all night. Can I change the battery?
press and hold the power button 10 sec ?
Press and hold both power and volume down buttons for 10 seconds, then release vol. down button while holding down power button for another 10 seconds, before releasing.
plug to pc and wait to be recognized?
take out the battery so that samsung fully discharge so this should help reset replug the battery.
Jan 04, 2015 | Supersonic 9.7" Android Tablet SC-97JB
How do I fix my tablet that won't fully charge?
Your tablet may need its battery calibrating. To do this run your tablet until it turns itself off, this will ensure that there is no charge left in the battery. Then leave it on charge until the battery is full. Normal battery use on modern devices like tablets and phones should be between 25-75%, with a calibration once every 3-6 months to ensure a good battery lifespan. If this solution does not work you may need to replace the battery.
Jul 07, 2014 | Visual Land Connect 9" Android Tablet...
I have a android jellybean 4.2 tablet when you put it on charge comes up with charge symbol then when you try turn it on it comes up with the android symbol filling up with jelly beans then lights word for...
Check by replacing the battery. If battery is weak [in terms of current storing capacity], the phone will show; as the battery is fully charged, but, when the software starts to load, the voltage of the battery will go very low than normal. If so, the fault you indicates here can happen. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 08, 2014 | Tablets & eReaders
I have a tablet,when i power up the name android appear and still loading until my tablet gets low battery
First make sure the tablet is fully charged, then perform a reset. From a power off condition, press and hold the Power and Volume (+) buttons until the reset routine starts. When it is finished you can try to start again.
Feb 27, 2014 | Android Tablets & eReaders
Just recieved my tablet and lock indicator is on, how do I unlock for first time use.
Try pressing on the lockwith your finger and sliding it to the right. Hope this helps.
Dec 30, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
Tabeo won't fully charge
I spoke with someone in their Tech department today about another problem and mentioned that I was having problems with it charging and he said that when I get back the device there is an update that needs to be installed in regards to the charging problem. So when you get a chance install all updates.
Jan 05, 2013 | Toys R Us Tabeo
How do i unfreeze my android tablet
My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
Oct 28, 2012 | PANDIGITAL SuperNova
I am having problem with may X touch android tablet there is no any display
my x-teach tablet screen broken so i would like change the screen please give me service cemtre address
Aug 04, 2012 | Tablets & eReaders
Tablets & eReaders Logo
49 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
