Question about Sony Audio Players & Recorders
Hello, i have Sony MCH-RV6 cd tray was not ejecting, not playing can please suggest me to fix this problem.
2 Suggested Answers
SOURCE: Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
I had the same problem but fixed it by replacing the cd belt which was broken and relined the main cd plate which holds cd to correct position . and god fixed it.
No more errors and now a great cd Hi Fi.
Make sure all s aligned and blow out all dust with an blower or air compressor.
I pull the top plates off blow air into them and replaced a broken belt for cd's and not it's new machine.
You want to fix it than fix at the source.
Posted on Jan 08, 2011
I have a sony cdp cx355 that seems to have a disc stuck and the door will not open to remove it. How should I proceed?
You have to remove the cabinet to expose the inner workings. Once inside, you should be able to see the stuck CD. Be careful to avoid damaging any parts of the player mechanism as you work the CD back into the carriage. You may find that once the CD is back in place normal operation resumes.
Sep 04, 2016 | Sony MegaStorage CDP-CX355 300-Disc CD...
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
Protect push power/ sony- MHC RV6
A protect message on a sony usually means there is an amplifier problem.
Jul 19, 2013 | Audio Players & Recorders
My Sony CD Player Won't Play
before yo junk it try this procedure.
1. try to used cd lens cleaner.
2. if no helped try to manually clean the lens,
3. open the cover.
4. power on the unit.
5. push eject button.
6. after eject then power it off.
7. you can now access the lens, try to clean the lens using cotton buds and small amount of alcohol then wipe it out or you can used microfiber cloth.
Hope it helps please rate my answer.
Nov 07, 2012 | Audio Players & Recorders
Hello, I have a 6 cd changer that will not eject a cd. I have had no problems till now. I ejected a cd that had been playing to see what it was. I put it back in and it is trying to eject but will not....
There are 3 possible faults.
1) The CD has slipped and is jamming the tray.
2) The Tray Drive Belt is slipping or has snapped.
3) The Tray Drive Motor has Failed.
If you take the cover off you should be able to see which of the above is at fault.
1) & 2) are easy fixes but 3) could be more difficult depending on access to the motor and availability of a replacement.
If you require any further assistance once you've opened the unit then please ask for clarification.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose Audio Players & Recorders
Cd drive wont eject
Try ejecting it through "My Computer". Right click on the drive and select "eject". If you can't locate the drive, then it's probably missing the driver.
Nov 25, 2010 | Sony VAIO VGN-NS240E/W Notebook
How to play a cd
Usually the DVD drive or the CD drive has a very small button on the front side of the Drive, if you see a button press it, the tray will come out and you will be able to put the cd on the tray and than press that button again it will take the cd in and will play for you.
However if you feel that difficult, try doing this,
simply go to MY COMPUTER, there you can see your dvd-drive or cd-drive, you can right click on the drive and click on "eject" it will eject the tray just like a normal dvd or cd player and you can insert the disc to play.
if there is anything else i can help you with please let me know.
Thank you.
May 18, 2010 | E-Machines eMachines Desktop PC
Sony Vaio VGN-AW21M OPTICAL DRIVE PROBLEM
replace drive 35-50 bucks i reccomend a lite on
Aug 22, 2009 | Sony VAIO VGC-RA840G PC Desktop
Tray will not eject on LTR 16102B CD-RW
Most likely due to a worn belt. You can use a paper clip in the manual eject hole while pressing the button repeatedly to get it open. The belt or the drive will need to be replaced.
Jul 07, 2008 | Lite On LTR 16102B CD-RW Burner
80 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
