Question about Refrigerators
What is the part number for the compressor relay and price? Where do I order it?
The compressor it's over freezing because the relay is not working correctly
  • Refrigerators Master
  • 932 Answers
Jorge,
Here is a link to repairclinic.com. You will need your make and model number to find what you are looking for.
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Posted on Apr 21, 2015
Neither compartment hasnt worked in 2 day fan is on continusly. cleaned coils of dust now in hearing a clicking ever 2 minutes could it be low anti freeze
This means the relay to the compressor failed to run the compressor, so check the relay and replace if needed. if with a new relay the compressor doesn't run than the compressor could be lock and would need to be checked or replaced. Its really hard to give you more information without a model number are not every model works the same anymore. I hope this leads you in a quick resolution of your issue. Good Luck
Aug 16, 2014 | Refrigerators
WHATS THE PRICE OF COMPRESSOR RELAY FOR VISSANI HVWC28ST
I would recommed contacting the Magic Chef web site to order the right part. I did and it was well worth it and my replacement seal worked perfectly.
Jun 23, 2014 | Magic Chef MCBR440 Compact Refrigerator
Kenmore model (p) 66992 fridge with bottom freezer.Fan is working on bottom but fridge and freezer are not getting cold.
If the compressor is not operating to cool the unit then the most likely causes are the relay or the capacitor or the compressor. If the compressor is extremely hot then that tells you the compressor is getting power but not working. If it isn't hot then it probably mean that either the relay or the capacitor is not allowing power to get to your compressor.
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/W10293291/0046/106/Model-59669928011/0582/0161000?keySuffixId=NA&productTypeId=x&searchModelNumber=59669928011&subCompDesc=Unit%20parts&brandDesc=KENMORE&modelDesc=REFRIGERATOR&blt=11 Relay
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/2169373/0046/106/Model-59669928011/0582/0161000?keySuffixId=NA&productTypeId=x&searchModelNumber=59669928011&subCompDesc=Unit%20parts&brandDesc=KENMORE&modelDesc=REFRIGERATOR&blt=11 Capacitor.
The part numbers on those links are searchable so you can look for cheaper prices.
Jul 19, 2011 | Kenmore Refrigerators
Fan coil freezes
Hello, the coil can freeze due to a dirty air filter, dirty evap coil or a low refrigerant charge. First, check the filter make sure it is clean, if not wash the filter. Next check the evaporator coil and and clean if dirty, the coil can be cleaned with a can of coil cleaner which you can buy at a hvac supply store. If that checks out ok then the unit has a low refrigerant charge and must be recharged by a hvac technician.
Apr 25, 2011 | GE AJCQ12DCD Air Conditioner
Roper Freezer Stopped Freezing
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 02, 2009 | Refrigerators
Fridge not cold and freezer not freezing
Jun 30, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerator is not cooling properly/fan is not running
HI,
The click and hum your hearing is most likely the compressor trying to start. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
anu further question don't hesitate to contact me.
thanks,
Mar 23, 2009 | Refrigerators
Both sides do not freeze or cool
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
most common problem is a bad start relay on the compressor. in rare cases the compressor may be bad. if you are mechanically inclined you can replace the relay yourself for less than 50 dollars. you will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
thanks,
Mar 22, 2009 | Maytag MSD2432G Side by Side Refrigerator
Amana/Maytag ACD2234HRS sometime not working
If your compressor is running with the noise you described, I would make sure the parts that were replace on compressor are working properly. Also use a amp meter and get a reading on amp draw while it is humming. Anything that is above normal readings for the compressor would indicate compressor is bad or the relay and starter are not working properly. I need a series number also like a number 15 before the model number, Thanks, Sea Breeze
Mar 21, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
