Question about Frigidaire Washing Machines
I have a frigidaire affinity front load washer. It will start fill with water and then it pauses. It works fine onspin only cycle. It will work sometimes and go through the cycles then it stopsagain.
    Genius:
  • Frigidaire Master
  • 1,585 Answers
Ide replace door inter lock
Posted on Apr 27, 2015
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
SOURCE: Affinity E21 error
E21 means "Not pumping out fast enough". Could be debris caught in the pump inlet sump or pump body.
a75737b.jpg Disconnect the inlet sump from the pump. Disconnect the outlet hose from the pump. Remove the (2) screws, one on each side, holding the pump housing to the washer base. Unplug the wires from the pump motor and lift the pump assembly out.
Posted on Feb 08, 2008
onthejob5130
  • 640 Answers
SOURCE: My front load washer affinity pauses 3 or 4 times during a cycle
the unit is waiting for something,,,like water ,,,or a slow drain..you must see where the unit is ,in the cycles,,and make sure that action the unit is trying to do is able to do...onthejob
Posted on Feb 01, 2009
Jahn27
  • 1554 Answers
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Jul 13, 2010
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
What is making my Frigidaire Affinity Washer FAFW3801LW fill and start working and then after 2 minutes there is an ugly noise and it displays "pause"?
Good Morning Doina,
I understand your Frigidaire Affinity washer, model# FAFW3801LW, will fill and start working. I also see that after about 2 minutes, you hear an ugly noise and your appliance displays "pause". I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FAFW3801LW Washer
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front loading washer keeps pausing during sanitize cycle
Sounds like the unit might be sudsing up too much or something is not allowing the sensors to operate and advance to the next cycle. Contact your purchasing dealer and have them come out since it is so new and under warranty.
Jul 30, 2012 | Frigidaire Affinity FAFW3577K Washer
I have a frigidaire affinity front load washer that will not lock and start. I turn the dial, all pertinent lights come on, but no door lock and it alternates between cycle time and "Pau" which...
is there any water in the drum if no then it could be your door catch try shuting the door with a bit more force or pushing on the door when you turn on the machine if it does not start then it will be that you will have to replace your door catch
Oct 15, 2011 | Frigidaire Affinity ATF7000E Front Load...
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Jan 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
