Misplaced owners manual for keys KBSB7393, I paricularly need the plumbing parts/numbers as I have two leaks. One on each side of tub, have pinpointed where. Thanks
    Sergeant:
  • 361 Answers
Goto their website ,
Posted on Apr 21, 2015
  • Crystal Walts
    Crystal Walts Apr 21, 2015
    I guess they went thru bankruptcy, no site under that name.
    Thanks for your suggestion :)
2 Suggested Answers
kelles34
  • 11 Answers
SOURCE: Frigidaire top loading washer Model
unfortunately that part is no longer available and there are no subs....sorry but you will need a new washer
Posted on Oct 25, 2010
Nordic hot tub
All the plumbing on these items are accessed from the outside. You will have to remove the siding/skirt. Dont just cut a hole in it. Plan this out so that you can cover it with trim. You may end up making a large slice in the siding.
Nov 24, 2013 | Plumbing
Delta T2738 Deck Mount on Jacuzzi Tub. Hot Water side leaking.
With the detailed part number you have, I would just walk into stores like Home Depot or any plumbing store and they will give you the exact parts you need. They are not expensive and a lot of them are standard parts and come in kits.
Good luck.
Apr 08, 2013 | Delta T2738 Lahara Deck-Mount Two-Handle...
Replacing hot tub flow switch
Depending on what type of flow switch is in the plumbing will determine how it is changed out.
These are usually glued into the plumbing line with no unions or gate valve on either side of it,
If this is the case for you tub then you will need to drain the tub or isolate it from the water so you can plumb in a new flow switch.
Rod
US Parts Center
888-521-6183
Feb 15, 2013 | Qca Spas Pool & Spa
Hot tub leaks, not from pump or heater.
Most leaking plumbing issues from a spa are to in depth for a home owner to pay for the repair. Use MARLIG FIX A LEAK and this will fix almost any small-medium leak.
Sep 06, 2010 | Pool & Spa
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
Jan 03, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Hot tub
go to the manufactures website or just google (the name + service manual/owners manual)
Apr 10, 2009 | Waterway 4 Hp 230 Volt 1 Speed Side...
Whirlpool Refrigerator: Side by Side Not releasing made ice.
The evaporator system that release the ice is not working, test evap fan and motor , and test the heating coil on icemaker evap system.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 14, 2009 | Whirlpool ED2FHSS Side by Side...
Need a new power cord....misplaced mine...
i did the same thing. replacement at radio shack.
Jan 17, 2009 | Technics SA-EX140 Receiver
Washing Machines Logo
Top Washing Machines Experts
