Question about HP Computers & Internet
Bios password reset for 2760p
It shows up after the system power on
    Sergeant:
  • 180 Answers
Hi
Replace the BIOS chip.
regards
Posted on May 19, 2015
4 Suggested Answers
supertex
  • 30 Answers
SOURCE: reset power on bios password on compaq 2200
theres a small battery in you computer you have to pull for like 5 minutes you can find out what it looks like on youtube.com or wonderhowto.com
Posted on Mar 24, 2009
  • 42 Answers
SOURCE: i need to unlock password on my hp elite 2760p, can you help or give me link or download
Nowadays,lots of methods help us to reset windows password,such as use safe mode, password reset disk, and windows password software as Windows Password Reset ect.
The details in http://www.windowspasswordreset.net/article/article.html
Posted on Jul 09, 2012
  • 87 Answers
SOURCE: hi... i have reset the bios password
it would be best to take it in as it normaly requires opening up the laptop and clearing it with jumpers,dip switches, or a well placed paperclip depending on the relevant laptop or pc that is best left for professionals
Posted on Apr 11, 2013
Bios password Dell XPS M170 how do you unlock it ???
How to use the jumper to reset the BIOS password on your Dell desktop computer
Summary: If you're prompted for the Basic Input/Output System (BIOS) password at startup (before the operating system loads) or the BIOS or CMOS setup is locked, and you don't know or have forgotten the password, you won't be able to use your computer or change BIOS settings. Use these instructions to reset the BIOS password manually using the jumper.
NOTE: This process will not clear a Windows Operating System password, nor will it clear passwords on a Dell portable computer. This is only to clear System BIOS passwords on Dell Desktop and Mini-Tower systems.
Desktop system BIOS password reset.
NOTE: The BIOS is the program that activates the hardware required to start your computer. The jumper is a small plastic covering found inside your computer.
Before you begin
Perform the safety steps in the order below.
WARNING: These steps are for your personal safety and the protection of the equipment.
  1. Turn off the computer and unplug the power cable.
  2. Wait 5 seconds.
  3. Disconnect all external devices.
  4. Disconnect any telephone or network cables from your computer.
  5. Press and hold thePowerbutton for 10 seconds while your computer is unplugged to release static electricity from the system.
  6. Before touching anything inside your computer, ground yourself with a wrist-grounding strap or by touching an unpainted metal surface, such as the metal at the back of your computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
To use the jumper to reset the BIOS password
NOTE: On the DellManualsweb page, download the Setup Guide or Service Manual for your computer. Then refer to the System Board Components section for a labeled illustration of the jumpers on the system board.
  1. Ensure that your work surface is flat and clean to prevent scratching your computer's cover.
  2. With your computer still turned off and unplugged, remove your computer's cover.
  3. To locate the password jumper on the motherboard, look for the letters PWD, PSWD or PSWDCLR.
  4. Choose an option:
If there are 2 metals pins under the jumper
  1. Remove the jumper from the pins, replace the computer cover, reconnect the power cable and monitor and turn on the computer.
  2. After the Windows logon screen appears, turn off the computer.
  3. Again, disconnect the power cable and monitor. Press and hold the power button for 10 seconds to release static electricity from the system.
  4. Remove your computer cover.
  5. Replace the jumper in its original position covering the 2 pins. This will re-enable password feature.
  6. Replace the computer cover.
  7. Reconnect the power cable and other connections and turn on the computer.
If there are 3 pins under the jumper (See figure 1. below.)
Figure 1. Generic motherboard illustration showing a 3 pin password jumper, you motherboard may vary, see the owners manual for you system for specific instructions.
  1. Remembering which two pins are covered, remove the jumper from those pins.
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
  4. Turn on the computer and wait 5 seconds. Then press and hold thePowerbutton until the computer turns off again.
  5. Disconnect the power cable and monitor again. Press and hold thePowerbutton for 10 seconds to release static electricity from the system.
  6. Replace the jumper over the original 2 pins.
  7. Replace the computer cover.
  8. Reconnect the power cable and other connections and turn on the computer.
May 06, 2017 | Dell Computers & Internet
Hi... i have reset the bios password
Apr 11, 2013 | Samsung - Laptop R480 / Intel Pentium...
How do i reset the bios password for my lenovo a310?
User passwords:
Power on
BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive
The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords:
Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password."
c.gif fw.gif Client Security Solution
Mar 13, 2011 | Lenovo IdeaCentre A310 Laptop
BIOS password or master password
Remove your BIOS Battery and after some time reset again after some time , if it does not work then unplug your bios zipper it will work........
Apr 28, 2010 | Dell Inspiron 700m Notebook
I need to reset, bypass, or remove the HDD1 PW
Shutdown The System
Press ESC and Power button together
Enter the passwords if prompted
Press F1 to enter the BIOS
Select the password field (it shows Registered)
enter bkspc or space
enter your existing password
press enter
It prompts for New password
Just enter
Repeat for verify
Now password is Unregistered
If you found this post helpful , please rate it!
Regards
1234s282
Apr 17, 2010 | Toshiba Satellite X205 Notebook
Tecra , laptop bios password needs to be reset.
mera laptop
think pad r40e
bios pass word
my bhool gaya
pls mere ku help karo
Feb 17, 2010 | Toshiba Computers & Internet
Can't remember password
BIOS password remove alternatives:
1. Reset Password BIOS via Backdoor BIOS Password.
2. Reset Password BIOS via Software.
3. Reset Password BIOS via hardware.
4. Reset Password BIOS via default manufacturers.
OK, here is my guide to Remove Acer Bios password computer via Software. This has been done on testing machine Laptop Acer Aspire 3620/ Travel Mate 2420. Anyway, I'm not sure it will work on every Acer PC/Laptop so just consider to do at your own risk, I’m not responsible for any damages caused by this guide.
As we know most of Acer computer (Laptop & Desktop) allow us to setup BIOS in Microsoft Windows (9x/XP/Vista) environment. Great, this is the powerful that help us to remove the BIOS password cuz all we know if we enter Setup Utility at the boot time we have only three times of filling the password and if all wrong then the system will halt.
The program helps us to enter Acer BIOS setup in Microsoft Windows is “Acer eSettings Management” which comes with the CD when we buy Acer PC/Laptop. If you lost the CD then just come to Acer website to download the program.
Feb 02, 2010 | Acer Power 1000 PC Desktop
I have an acer laptop 2920 i lost the password which has locked
There is only one way to clear cmos (BIOS) passwords and I'll show you the procedure.....
Steps for Clearing BIOS Password Check
If users set BIOS Password ( Supervisor Password and/or User Password ) for a security reason, BIOS will
ask the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
q Power Off a system, and remove HDD, AC and Battery from the machine.
q Open the back cover of the machine, and find out the HW Gap on M/B as picture.
q Use an electric conductivity tool to short the two points of the HW Gap.
q Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
q Restart system. Press F2 key to enter BIOS Setup menu.
q If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password ( Supervisor Password and User Password ).
Below is the picture showing the location of the jumper next to the memory module slots. This is the jumper connections that have to be "shorted".
Jan 28, 2010 | Acer Aspire 4720 Notebook
Xe2 power on passsword
find the system reset button....if u can find it then remove the CMOS battery for a few minutes at least 5. then in your post it will show you a mask systems had been reset and you need to configure your bios.cmos. if you know how then just select what you know is right for your system. then reboot and your password is gone.
Apr 06, 2008 | Intel Motherboard
Bios reset
As another option you could try resetting the jumper. Some boards save the password regardless unless the reset the BIOS by using the resetting jumper. Refer to the motherboard's manual for further information on how to do this.
Oct 10, 2006 | Acer (ACERMOTHERBOARD)
Computers & Internet Logo
172 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
