Question about Baby Gear
Can I put pushchair forward facing if so how do I do it
Graco Super Seville Pushchair How do I adjust the 3 postition seat
Hi there
At the back of the seat is a metal bar, pull that up and pull the seat back.
I've found with mine that if the handle is one of the two positions (can't remember which, I think it's for forward facing pushchair) you can't recline it at all. I have to move the handle the other way first then recline it.
To move the handle there are two button/levers, one on each side. Lift those up and the handle will move, make sure it then clicks into place.
Hope that helps
Aug 09, 2011 | Computers & Internet
Can you have the pushchair facing you.?
Good Morning
The Quinny Buzz can be used in parent facing mode in a series of comfortable recline positions.
Aug 07, 2011 | Quinny Buzz Three Wheel Stroller
Hold can i fold down my quinny buzz
Find the grey buttons on the centre of the frame either side at the bottom of the handle (the bit where your carseat/pushchair seat unit fits to the frame), you will find that one pushes in whilst the other pushes in and moves forward. Now stand in front of the pushchair with the front wheel against your foot, push in the left hand grey button whilst pushing in and pulling forward the right hand grey button, now pull the frame towards you and down to the ground. It should start to move, if not release the buttons and try pressing/pulling them again until it does. Look on u tube if you are still having problems - or go to Mothercare and ask them to demonstrate on their store one.
Jul 06, 2010 | Quinny BUZZ 3 Capri Stroller
Pushchair wont fold down
sounds like its still locked somewher look at back an lift bars make sure seat unit is up an not lay down unclip hood try them and see
Apr 03, 2009 | Baby Gear
How do you changeover to carry cot from pushchair?
The seat does not come off the Raider At+ as it is a forward facing pushchair only. You can attach a Raider carrycot on top of the seat. You lock the wheels by the mechanism on the left side moulding.
Feb 27, 2009 | Bebecar Raider AT Stroller
Forward and Backward facing Quinny freestyle 3xl
I have spoken to the friend who has the freestyle 3XL, and has her pushchair facing backwards (not the car seat, but the actual pushchair). It seems it depends on what age model you have. On mine (sadly) I cannot turn the seat around. However, on the ones which can be adjusted (possibly the newer models - mine was 2nd hand), look under the foot rest. If yours can be adapted, there should be a lever under there which enables you to turn the frame around. If there isn't a lever then it's probably not one that can be swapped.
Hope this is helpful and that yours is one of the models that can be altered!
Feb 07, 2009 | Quinny Freestyle 3 XL Stroller
Bebecar raider at+
The Raider At+ is a forward facing pushchair only.
Nov 02, 2008 | Bebecar Raider AT Stroller
Reversible pushchair seat
What brand sroller is this?
Apr 18, 2008 | Baby Gear
Lost instructions
If you know what kind of item it is. You can go to the industrial web site. Put in the kind of item it is also the name.
For exsample: < industrial produce & name, manual >
Oct 27, 2007 | Silver Cross 3D Stroller
Baby Gear Logo
121 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
