Question about John Deere Garden
Have a j.d. gt262 and the spark plug and coil were replaced now it won't start any suggestions?
  • leslie woodard Apr 21, 2015
    The tractor started when ether was sprayed in carb but then it shuts off
    Sergeant:
  • 361 Answers
Did it start before are you getting fuel , take a little ether and spray it into the intake manifold and sees if it starts if so it is a fuel problem
Posted on Apr 21, 2015
    Thank you for your help.
  • jack of all trades ,
    jack of all trades , Apr 22, 2015
    if it started with the ether you have a fuel problem , check the fuel pump sending unit , if it is a electric pump make sure you are getting power to it first, then ck to see why it is not sending fuel to the carb or injectors , that is your problem ,
fastboyz
  • 674 Answers
SOURCE: starting problems
did you get a good answer to your question?
Posted on Sep 16, 2008
  • 104 Answers
SOURCE: my 1997 ford f250 cranks but wont start,replaced
check fuel pressure-then timing chain
Posted on Sep 19, 2009
  • 176 Answers
SOURCE: No spark Power to coil New wires and new coil
Usually the ignition controll module or pickup coil. Your local auto parts store should be able to test the module for you.
Posted on Nov 05, 2009
cansmo
  • 2431 Answers
SOURCE: code p2305 ignition coil b
The wire for the secondary on that particular circuit has to be tested If you have a ICM that secondary has to be tested there, If it is controlled from ECM it has to be tested at the ECM, because its a secondary wire it is capable of shorting the ICM or ECM it self, you only listed the year and.no engine size.
Posted on May 06, 2011
short shadey
  • 421 Answers
SOURCE: Galant won't turn over when
you now need to check for 12 volt power, and signal to the coil, also be sure all you timing marks are correct, if you have no spark, unplug one of the injectors and using an led test light check for injector pulse power across the two terninals while cranking, if you have no injector pulse then you could have a problem with the ignition passlock system, or key decoder
Posted on Jul 31, 2011
Volvo Won't Start
Replace your spark plugs and spark plug wires. This will probably fix your problem. Be sure and check your firing order in case one or more plug wires are hooked up wrong. This sounds like it might be your problem.
Feb 09, 2018 | 1984 Volvo DL
2004 lancer won't sart
have you got the timing set correct ,and did you fit the timing belt with all the timing marks lined up ,etc , if there correct ,check for spark ,by pulling off a spark plug lead and fitting an old plug into the lead ,then crank the motor ,dont hold the plug with your hand ,use insulted pliers ,if you have spark, ,if no spark check coil wiring ,coil, crank angle sensor,
Jun 08, 2012 | Cars & Trucks
1992 mx-3 v6 won't start. will hit sparaticly as if about to start but just won't catch. checked crank pos. sensor. need suggestions on how to proceed.
Check for a blue snapping spark on 2 or 3 plug wires(or all of them). If you get good spark, then ignition is likely not the problem. A weak or sporadic spark could be a bad coil or coil pack, or a bad ignition module (the ignitor).Check the coils with a volt-ohmmeter per the specs for your car. The ignitor can be tested at a parts store.
If spark is good, check fuel filter, fuel pressure, check timing marks on crank pulley and cam marks, Try a little starting fluid in the air intake and see if it runs for a moment. If so, then it's likely a fuel delivery problem. If no change, then it's likely an ignition circuit problem.
Good luck.
Dec 30, 2011 | 1992 Mazda MX-3
I'm only getting spark out of one of the coil packs and the car turns over put won't start, please help me. Thank you
Try switching the ignition coil with the other coil and plug it in and check for spark again. If it works in the other coil location, then you need an ignition coil. Your engine is bad for valve cover gasket leaks which deteriorate the spark plug wires, so if you are going to put in plugs and wires with the new coil, I would recommend replacing the valve cover gasket and spark plug tube seals(included with the valve cover gasket set).
Jun 21, 2011 | 2000 Mitsubishi Galant
1986 chevrolet celebrity i have no fire to the coil from the switch is my problem in the steering column because the column is loose and shakey
If you are not getting spark at the coil, then you're coil may need replaced. Also, pull the distributor cap and check the cap on the inside as well as the rotor. If you have not recently tuned up, then I suggest replacing the spark plugs, spark plug wired, (coil wire should come with them); the coil; distributor cap and rotor. When doing the spark plugs and wires, start with one, and replace the plug, then the wire for that plug - do this one at a time - do not take them all off at once, unless you have a book that shows the firing order. (Having a book for any vehicle is a good idea). Please let me know if you have any further questions, or need further assistance.
In addition, if this does not suffice - replace the starter relay. If this is blown, the car won't even turn over.
carsandcomps,
Guru, Premium Expert, Phone Expert @ Fixya.com
May 26, 2011 | 1986 Chevrolet Celebrity
My 1996 ford taurus sho wont start, it will turn over but not start what could be wrong?
Hello and welcome to FixYa!
Looks like that there's no current flowing that's why it won't fire up. I strongly suggest that you check and replace the coil pack if necessary. If the coil pack is faulty there will be no current to the plugs. One good reason why it won't fire up.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 25, 2011 | 1996 Ford Taurus
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
