Question about Garden
Need to where grease fittings are? - Garden
    Sergeant:
  • 361 Answers
Most of the thing made today do not have grease fittings but if you know where they should be then look there , your mower should have one on the drivshaft maybe and ck the front wheels , it is pretty much everything that moves ,right
Posted on Apr 21, 2015
Where are the grease fittings
Gary, You should consider getting a manual, Check the attached links,instruction and guides on where to find grease fittings on ATV's, Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Atv Maintance Grease Fittings
Can Am Outlander Renegade G2 Grease Fitting Locations
Time to Lube Up Your ATV Dennis Kirk Powersports Blog
Service Manuals for Download in PDF
Mar 31, 2016 | ATVs
How can I remove the pressed in grease fitting on a 1930 Ford
Grab it with a good set of vice grips and work it out, I have had grease fittings that won't take grease and some of them the parts had to be removed and the lube hole cleaned out. you can also buy a grease injector that is a hollow barrel with a plunger that fits down in it and you pull out the plunger fill the barrel with grease install the plunger, place the injector on the grease fitting and hit the plunger with a good size hammer
Jan 12, 2016 | Ford Cars & Trucks
Where are the grease fittings on a toyota2007 tocoma
Not all vehicles have grease fittings. Some are sealed but if it absolutely needs grease then put a needle nozzle on your grease gun and put pin hole into grease boot on ball joint, tie rod,etc. and give it some grease.
Sep 13, 2014 | Cars & Trucks
How do i grease the ball joints 1992 Nissan Sentra E
Here's a link to the lower ball joint,it tells you about a fitting to be greased,as you see the ball joint has a hole at threads where greasing fitting will be.It will be best to jack up and remove tire to grease,look for other grease fittings,wipe up excess grease.Also check ball joint for wear,may need replacing.
Jan 20, 2013 | Nissan Sentra Cars & Trucks
Does a 201 pontiac sunfire have grease fittings?
alot of these cars don`t have grease fittings from the factory as they are considered lifetime(permanent) greased components.however this doesn`t always work.if the components have at one time been replaced then they will have a grease fitting in them that needs to be greased.
Jun 29, 2011 | 2001 Pontiac Sunfire
Have 20,000.00 miles on car and the front end makes a creaking noise when turning steering wheel...need to grease but no grease fittings how do you get rid of noise
most newer cars came that way so you cant grease them this way you almost have to buy after market with grease fittings thay get you coming and going the only thing you can try is p-b blast spray it on the parts and hope it works good luck let me no if you need any thing else.
Apr 24, 2011 | 2000 Lincoln Continental
How do i make sure i have greased all of my grease fittings
You should have one fitting on each upper and lower ball joint, (4 total), and you may or may not have fittings on each of the four tie rod ends. Don't overgrease any of them, they only need one or two strokes of the gun. I think that is all you have. Some cars have a fitting on each end of the upper A-arm, but GM generally uses a rubber bushing there instead, no grease required. The lower suspension arm to the frame is almost always a bushing and needs no grease.
You *might* have fittings on your driveshaft universal joints, although these need a special "needle" fitting to reach them. Most u-joints don't have fittings, however. If you have them, they are standard fittings located in one of the four inner "corners" of the joint, near the center.
Oct 10, 2010 | 1997 GMC Sierra
Where are the grease fittings on the front end on my 2004 Pontiac Montana
many vehicles no longer have grease fittings. This does not remove the need for lube, however. When items fail be sure to install aftermarket parts (like Moog) and they will have grease fittings.
Sep 03, 2010 | 2004 Pontiac Montana
Do I need to add a grease fitting for the Steering Rods?
those other components are sealed and supposedly do not require added grease. You are able to go to a part store though and purchase a grease needle to inject into the boot if you feel it needs it.
Sep 03, 2009 | 2004 GMC Savana
Cant find grease sert on front end? 06 ram 2500 4x4.
if there is no fitting it is a "sealed" joint... either drill out a hole in the end and add a fitting for grease.... or when it fails replace it with one that has a fitting. i believe most hardware stores stock grease fittings
Robert
Dec 19, 2008 | 2006 Dodge Ram 2500
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
