Question about Music
What type of inputs are on the idm02(mono/stereo)?and hi hat type?
  • 7,733 Answers
Posted on Apr 21, 2015
  • Boses Maloney Apr 21, 2015
    I appreciate the help but I had already tried that manual. It was just regarding the setup and not much info on the specs. I did find it uses the same pedals as the alesis dm05 I think~~? Thanks again though
Stereo channels of Xenyx 1202 are very very quiet
It sounds as if the input is too low. what happens if you plug whatever is going into the stereo channels into a pair of mono channels. Or are you taking about the phono stereo tape input?
The stereo channels are line level whereas the other channels have both line and mic level inputs, what are you trying to put through the stereo channels? You must make sure the gain switch is set to the -10dB to get the most sensitivity (the mono channels have about -132dB max sensitivity BTW) You probably need a different mixer or possibly a submixer if you are needing more than 4 low level inputs.
May 06, 2014 | Behringer Music
I have connected a laptop to a Phonic MM 1002a mixer, Do you need to use both Channel A & B on Peavey M - 2600 Mark V Stereo Am
This depends on what you are trying to do. If you want a mono output from the amp switch it to mono mode and go into one input on the amp, this will mean the amp only works mono.
If your source is stereo you will need to use two inputs on the mixer and pan them both to the side you will be sending to the amp. This will cost you two mono inputs on the mixer though.
If you have anything stereo this is the route you will need to take but I don't see why you would want to do this as surely you'd be better running everything stereo (two channel) and panning any mono signals where you want them and leaving stereo as stereo.
Jan 02, 2014 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
I can only hear one side of my headphone with the Samson S-Amp! wheni pull the headphone cable out i can hear on both ears. what kind of connection do i need to listen in stereo?
Are you using a STEREO input cable? Is the source of the audio stereo? The stereo cable will have three connections on the plug... the sleeve, the ring and the tip.
If you only have mono source or using a mono cable you will only get sound in the left headset. Pulling the plug part way out will sometimes contact both connection so you will hear both.
If your source is mon, you will need a special cable that connects the mono signal to both sides of the input plug, that is the ring AND the tip.
Mar 29, 2011 | Samson Samp Headphone Amplifier
Alesis sr16: How do you hook it up??
Come from the main outputs, probably labeled L/mono and R and connect those to your mixer for your audio system on either stereo mix input OR two two inputs that are panned opposite.. DO NOT connect this to a consumer type stereo system as you may blow the speakers or amp. Consumer stuff just isn't able to take output from music equipment such as this UNLESS the volume is kept very low.
May 23, 2010 | Alesis Sr 16 Stereo Drum Machine
Connect active subwoofer to Studiomaster Walkabout
You CANNOT have a stereo set of RCA jacks "wyed" into a single XLR mono input.
The RCA output drivers will "fight" each other. Some things will appear to work, but give poor performance.
You could make a rudimentary passive mixer by putting a series resistor say 1K ohms from each of the RCA's to a common UNBALANCED input of a subwoofer.
The XLR is balanced so that would not really work unless you also have an unbalanced input on the subwoofer.
The right way to do this is to get a cheap two input mixer that has EQ with it and mix your two mains before sending to the subwoofer. You want a little mixer that also has balanced outputs (XLR or TRS) to send to the subwoofer.
UNLESS the subwoofer has EQ in it, you really need to have an EQ in the little mixer so that you don't send high's to the subwoofer... They don't like highs and the sound will suffer.
Feb 01, 2010 | Music
What's the best way to connect a PC (with DJ software) to a Fender PAssport 500 PRO (I want stereo input)?
Best way is to use a 1/8 TRS (stereo) to 1/4 TRS (stereo) cable from the PC into the Stereo 1/4 inch jacks right below the RCA stereo input jacks.
TRS stands for tip-ring-sleeve which means the jacks have the extra "ring" over a mono jack.
Jan 28, 2010 | Fender Passport Deluxe 500watt Sound...
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
Aug 04, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Confuse about the jack
Both stereo and mono jacks will work fine on the inputs, any guitar or mic lead will work a treat.
You can use stereo jacks for the outputs too, but to keep it simple just use a mono jack in the L out and a mono jack in the R out.
Oct 17, 2008 | Yamaha Mg82cx Stereo Mixer
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
