Question about Staples Tools & Hardware - Others
Not discharging Staples
I purchased a tacwise 71 upholstery gun with tacwise staples after connecting it up to compressor the gun fires but does not discharge staple, i think it is prob with staples not making contact with the piston blade when I fire trigger.The staples do not appear to fit into the grove for firing out. i have tried to push them as far as i can along the magazine unit as far a possible, did fire out 1 single staple each time a forced staple along. but it does not automatically do this on its own.
SOURCE: (DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Posted on Jun 28, 2009
faceofftech
  • 185 Answers
SOURCE: I have a manual Craftsman stapler 68447 and an
you can try here:
http://cgi.ebay.com/NEW-ARROW-1-4-MONEL-STAPLE-504M1-/220606637809?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335d2e26f1#ht_2432wt_911
I checked the crown website and it is a little bit harder to buy from them
if it works for you don't forget to rate me
thx
Posted on May 21, 2010
SOURCE: My T50P will not discharge
sometimes mine won't shoot, and i find a single staple in the track, almost ready to fire out , but can't , they can be hard to see in the tract, i keep sharp pliers on hand to clear them. hope this helps
Posted on Sep 30, 2010
  • 827 Answers
SOURCE: just bought TR110 staple gun
check the spring,. also there must be something lodged in it... look closer..
Ck
Posted on Feb 13, 2011
  • 13 Answers
SOURCE: i have rebuilt my staple gun all new seals new
Inside the cap, there's a plastic circular insert. It's a common mistake to reassemble the gun with this cap spacer upside down, resulting in the top of the cylinder not sealing in the air that returns the piston. Simply undo the cap, turn the spacer over and screw it back on again. Done.
Posted on Mar 14, 2011
Staples jammed.How can I unjam and open it?
Hi Alan:
You don't specify what make it is, or if it is powered.
If air, disconnect from supply, remove any staples from magazine, and attempt to discharge.
There will be allen head screws holding the firing mechanism assembly together. Always treat it as if it could discharge.
Carefully loosen the screws and try to remove the jammed staples with a small screwdriver. You may need to actually dis-assemble it to get it unjammed.
Clean parts, oil, and re-assemble.
Should be fine.
Feb 09, 2016 | Staples Tools & Hardware - Others
Upholstery stapler will not eject staples
sounds like they might be the wrong staple for the gun .
Jan 04, 2016 | Staples Tools & Hardware - Others
What are the best staples to use for upholstery
yes, yours are too narrow and the plunger grabs 2
Mar 05, 2015 | Staples Tools & Hardware - Others
Does it need Stanley staples?
I think you answered your self. A couple of thousandths of an inch can make a big difference.
Oct 20, 2014 | Tools & Hardware - Others
Has anyone found substitute rexel titan No 37 staples for the rexel titan tacker gun yet. The No 88 staples although they fit the gun do not fire as they are not fine enough .The original No37 ones are...
Rapesco Part number is: S14082M3. I've used these without problem
apparently Rapesco has now changed to Tacwise and they are now sold as
Tacwise 0346 (Type 140)
Oct 09, 2012 | Office Equipment & Supplies
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
My T50P will not discharge staples. I'm using the correct staples, there is no jam that I can see, and everything is well-lubed. It seems like the driver is not retracting far enough to allow a staple to...
Sep 30, 2010 | Arrow T50P ARROW STAPLE GUN
Cannot find staples for this staple gun. The model I have just says PowerShot on the sides. I purchased some Black & Decker PowerShot heavy duty Staples for the gun but I cannot find anyway to get...
The ones you have are T-18 I believe
Fires 6 sizes of T50 type staples and drives 9/16 In. brad nails. Visual refill window and easy load chamber. Comfort grip.
•Uses Staples: PowerShot Staples, 97-010, 97-011, 97-012, 97-013, 97-014, 97-015, 97-030, 9/16 In.
•Brad nails
•Ceiltile 17/32 In., 9/16 In.
•T50 type staples, 505TML, 506TML, 508TML, 509, 50CT, 506SS, 504M, 505M, 506M, 508M, 509M, 504, 505, 506, 508, 509
•MFG Brand Name : Arrow Fastener
•MFG Model # : 5700
•MFG Part # : 5700
Aug 13, 2010 | Black & Decker 5700 Powershot Forward...
I have a manual Craftsman stapler 68447 and an electric Craftsman stapler 68417 and need to purchase 1/4"Monel or stainless steel staples to do some marine upholstery. Where can I find staples for either...
you can try here:
thx
May 21, 2010 | Arrow Fastener #508M1 T50 1/2" Monel...
Tools & Hardware - Others Logo
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
