PHOTO CONDUCTORS NOT PROPERLY SET ERROR...HOW CAN I SOLVE THIS HELP ME PLS
HOW DO I PROPERLY SET THE UNIT
Arius
  • 446 Answers
SOURCE: Color Photo Conductor Unit
the vertical line that you saw is an indication of either it is normally worn out, or something has caused the scratched, by any material ( PC drum is very sensitive to any material and can easily damaged or scratched any solid and unwanted dirt inside) see you actual meter reading. if it falls on the first thousand copies or print then it might have caused by a scratched, if it falls beyond the PM parts repalcement then there is nothing you can do but to replace this.
sometimes you can swap the colors, by the affected color use the yellow drum unit to the affected drum, the vertical would not that be obvious.
Posted on Jul 24, 2008
  • 9 Answers
SOURCE: Aficio CL3500N Photo Conductor Unit
If your print outs are clear and the PCU is surely new.
Press Menu
Scroll to Maintenance <Press Enter>
Scroll to Replacmnt Alert <Press Enter>\
Scroll to PCU <Press Enter>
Select Notify Later <Press Enter>
Good luck.
Posted on Apr 06, 2009
SOURCE: How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
Posted on May 26, 2009
  • 63 Answers
SOURCE: Install Photo Conductor
Perhaps, it is necessary to establish the necessary software.
http://filters.atspace.com
Posted on Aug 10, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: what shoud I do when error 84 replace
    Photoconductor is the part of the printer where the image gets created this is a very delicate and important part in the Laser printing process. If you open the printer and remove the toner, you should see it sometimes is like a green or blue color. The message 84 is just telling you that the photoconductor has reached the end of life and needs to be replace. Here is also a link on how to do the replacement http://bit.ly/bn2HFc
    Posted on Feb 09, 2010
    Functional problem sc 302 in ricoh photocopier model aficio gestetner 1802d, pls help me out, nobody want to help i begged you all. mordecai Olugbenga.
    that is a charge roller leak error. try a different photo conductor see if it goes away. If so could be charge roller bad or drum . if it has more then 60,000 copies on it rebuild it .
    Mar 04, 2017 | Ricoh Office Equipment & Supplies
    IS THERE A TRICK TO INSTALLING THE PCU ON THE CL3500N? IT SEEMS AS THOUGH IT SHOULD BE A SIMPLE PROCESS HOWEVER IT IS NOT LOCKING INTO PLACE. THANK YOU
    Photo Conductor Unit Color
    A Turn off the power, and then unplug the power cable.
    B Open the right cover.
    C Pull out the green levers on the left and right that are securing the inner
    cover.Replacing
    D Lift the inner cover until it stays up.
    E Remove the photo conductor unit.
    F Pinch the
    green lever to unlock the unit.
    G Pull out the photo conductor unit carefully.
    H Pinch the green lever to unlock the unit.
    I Pull out the photo conductor unit carefully until it stops.
    J Pinch the green part to release the unit
    .K Pull out the photo conductor unit carefully. Be sure to hold the unit with both hands, and pull it out carefully.
    L Take out the new photo conductor unit.
    M Remove the cap attached to the photo conductor unit. The cap is no longer needed and can be disposed of.
    N Remove the tape from around Photo Conductor Unit by peeling it down-ward, and then remove the unit
    Mar 11, 2011 | Ricoh Aficio CL3500N Laser Printer
    Reset pcu correctly
    Hi
    Thanks for using FixYa. It means that the photoconductor unit is not set correctly. You’ll need to reset the black or color PCU correctly. Match the green arrow at the tip of the photo conductor unit to the rail inside the printer. Make sure the green arrow fits securely on the rail before proceeding to the next step. If you do not attach the green arrow of the photo conductor unit securely to the rail, you may damage the photo conductor unit. Push the front of the photo conductor unit slowly, sliding the unit on the cover and into the machine until it stops.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Jan 31, 2010 | Gestetner Office Equipment & Supplies
    Printer prints out black very light
    First change you photo conductor unit if not solve
    change the developer unit ( Ink ) If not solve
    Clean the scanner glass of the printer.
    Note that don't displace the glass just wash with a white dry cloth
    Thanks
    Oct 26, 2009 | Dell 5100cn Laser Printer
    Printing problem
    Pull out the color photo conductor unit. If you see lines on any of the green drums replace the color photo conductor unit. You can also get color registration errors if the transfer unit is scrached. my first recomendation is to look at the color pcu unit and replace it if you see any lines on it. Also pull out and inspect the black pcu unit.Let me know what you find.
    Jul 07, 2008 | Ricoh Aficio CL2000 Laser Printer
    Solution to epson c1100 error message
    Turn printer off and remove photoconductor unit, close covers and turn printer back on without photoconductor, error will appear that you need to install photoconductor, install photoconductor and wait til it calibrates, if same error appears photoconductor is a consumable part you will have to replace it then.
    Pls dnt 4get to rate solution. TY
    Mar 18, 2008 | Epson Aculaser C1100 Printer
    What is service code 527
    The sensor under the photo conductor unit mounted on the metal bar is out of line and does not detect the dev unit in home position. Usually adjusting the sensor toward the dev fixes the issue.
    Jan 07, 2008 | Epson Aculaser C1100 Printer
    SC 441
    Hi there the following is the description from the service manual hope this helps you Thanks J
    441 PCU (CMY) motor error
    The drive motor of the CMY
    PCU is not locked.
    • Defective gear
    • Voltage between pins 2 and 14 (CN12 on engine
    control board) abnormal (not +24V), or pin 12
    (CN12 on engine control board) unable to send
    motor clock
    • Defective CMY PCU drive motor
    1. Replace the CMY PCU.
    2. Replace the engine control board.
    3. Replace the main drive unit assembly.
    I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
    Thanks J
    Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
    26 people viewed this question
    k24674
