I want the dsp rznc- d5416 update setupe whear can I find
  • Anonymous Apr 21, 2015
    any know that ? I will thank u if u can help me
How do i repair dsp fw update altec Lansing imt810
First, there is NO screen on the boom box.
The issue is with whatever you have the speakers connected to.
Mar 08, 2015 | Altec Lansing Audio Players & Recorders
How do i turn off the dsp and run stereo mode?
Pressing the PROCESS button opens up the various screens that determine the signal path setup and that control processing parameters for the DSP modules: I/O, PEQ, XOVER, DEQ, DELAY, and LIMIT.
I/O
The I/O module sets up the signal routing inside the DSP from input to output. Press and rotate the SELECT encoder knob to choose between dual mono, stereo, bi-amped, or bridged routing options.
STEREO
STEREO mode routes the signal from both the A and B inputs through a single series of DSP modules. The parallel DSP modules process the A and B signals with identical, linked settings (only module "A" parameter settings appear on subsequent DSP module screens).
The manual is available at: http://www.behringer.com/assets/NU6000DSP_NU3000DSP_NU1000DSP_M_EN.pdf
Jun 02, 2014 | Behringer Inuke Nu6000dsp 6000-watt Power...
Pioneer vsx-29tx has no sound update has been done dsp board different number
If your friend said the ROM chip was hit by lighting then most likely is is damaged.
Feb 05, 2012 | Pioneer VSX-29TX Receiver
Own a Yamaha DSP-A1000. Center channel "died" this week. Everything had been working for years. Suddenly, the center channel stopped working (very obvious in DSP fields for Home Theater). Any...
If you run through the setup and certify it knows about the center channel first, then test it with tiones, then maybe swap the center speaker with another one you might come to an answer.
May 13, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
No audio output
THE FIX - to audio problems that persist with the VSX-29TX and others using the AWX7272 DSP board is to replace the ROM on the DSP. My unit started failing on and off after 10 years of use! The intermittent DSP board is an Extremely Common and irritating Problem for this model! The replacement IC,(2) resistors + shipping and handling totaled $49.65 and my unit is finally fixed correctly! Don't believe other posts that you can get away with re-soldering; it will continue to fail again and again! Details of fix are:
Replacement for the old Pioneer ROM located at location IC 9374, should be done with the part PD6381A from Pioneer Electronics. You will also need to move (relocate) the 2 resistors (0 Ohm resistors) located at R9372 and R9371 to locations R9374 and R9373.
This component update applies to DSP boards marked as AWX7433, AWX7272.
This fix is validated (from Pioneer) on the VSX-26TX,VSX-27TX,& VSX-29TX it might also work in the VSX-908, VSX-908RDS and others as long as the same DSP board was used.
Let me caution and stress that surface mount soldering skills ARE REQUIRED to do this update! It also doesn't hurt to have excellent vision and/or an eye loop or microscope to check your work. Original ROM's were subject to timing changes internal to the part as a result of HEAT. This model does get HOT! The program was also modified as a further safeguard to re-occurrence.
Jan 30, 2010 | Pioneer VSX-29TX Receiver
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no...
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
Main:
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
SR8051:07601A
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
E1A48K0N/0FFPo
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
Nov 30, 2008 | Onkyo Audio Players & Recorders
No center main volume
Make shure your initial setup on the amp is for center as an active speaker,then to check volume on center at zero. Possible to check speaker and wires for open or short.BIGRED
Sep 16, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
66 people viewed this question
 Grubhead
Grubhead
