Question about Brother P-Touch QL-500 Lable Printer - Thermal Transfer - Roll 2.3 in
Having trouble installing the DK roll, where do I insert label end, tried it all!!!
2 Suggested Answers
  • 48 Answers
SOURCE: QL-550 Label Stuck
Normally theres a lever you pull (the same one you use to manually pull the labels through), if you pull that, you should be able to blow the label out, or pull it through.
Posted on Apr 24, 2009
Why is the red light flashing all the time
Indicates one of the following problems:
  1. Label Sensor Error (end of roll or paper jam)
  2. Incorrect roll installed (wrong paper type)
  3. Transmission Error
Aug 05, 2014 | Brother QL-570 Thermal Label Printer
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Replace the roll without black on white in DYMO 450 turbo
Most of the labels come with the black rolls already in place
i think you can just reposition the new labels on an old roll if the end isn't attached to the roll
Mar 14, 2014 | Dymo LabelWriter 450 Turbo USB Label...
Can not reload lables in the gun
Depending on the type of gun that you have, loading will vary. Here is the most common style of label loading:
Loading
  • At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
    Insert a roll of labels into the gun opening so that the beginning of the roll is at the back and comes up over the top of the gun. Insert the beginning of the roll into the slot, squeezing the trigger halfway. Push the labels through the gun until they come out at the front. Thread the labels up and under the black plate on the front of the gun and then under the rubber roller. Squeeze the trigger again and pull six or seven labels out. Discard the labels, leaving the paper backing. Thread the paper backing into the underside of the gun, next to the handle, in the direction indicated by the arrow. Push the paper backing while squeezing the trigger until the gun begins dispensing labels.ixzz18ERFHy
  • Dec 16, 2010 | Office Equipment & Supplies
    How do I load labels in monarch 1100 price gun
      Loading
    1. At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
      Printing
    1. If the print on the labels is off-center, place a penny in the slot on the right side of the gun and hold it in place. Using another penny, turn the adjuster on the left side of the gun in a clockwise direction, printing test labels to check your correction. Keep turning the adjuster until the print is centered.
      To replace the ink cartridge, turn the latch on the right side of the gun to an upright position. Pull the door out. The ink roller is on the end of the door in a plastic holder. Push the holder apart slightly to remove the old ink roller and insert a new one. Replace the door and turn the latch to hold it in place.
    Nov 29, 2010 | Monarch ® Pricemarker 1110 One-Line...
    My printer prints great until I get near end of roll.
    It sounds like a lower quality label material and possibly too tight winding on the label rolls themselves. Call BarcodeWarehouse.biz and ask for a free roll of theirs and see if you have the same problem.
    Aug 07, 2009 | Zebra LP 2844 Thermal Printer
    My zebra tlp2844 wont print, the red light on, i think we set the reverse sensor on , after it got this trouble. What should i do?
    Well are's was acting like what you discrive, I found that the ribbon,core tube has slots in the ends, this slots were, wear-out the ribbond wasn't moving thas why we were getting the red light, (error light) We install new rolls of ribbonds.
    Aug 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
    QL-550 Label Stuck
    Apr 24, 2009 | Brother P-touch QL-550 Thermal Label...
    Can i insert Two different coloureds Tag Rols in the Machine
    If you put 2 rolls in, the labels will float around, since there is no way to keep each loose end in place.
    Dec 23, 2008 | Zebra Z4Mplus Label Printer
    Brother P-Touch QL-500 Lable Printer - Thermal Transfer - Roll 2.3 in Logo
    594 people viewed this question
    CheckitRight
    CheckitRight
    Ron Dufek
    Ron Dufek
    James Cagle
    James Cagle
