Question about Samsung Washing Machines
How do i fix Samsung WF337AAR/XAA, water pump does not power?
Alright, i have had no luck with this issue. As with many it started off with the error code "nd" and so i checked for clogs and even took out the pump and cleaned it and checked for blockages. put it back together and went into test mode and got no response out of the pump, but everything else is working fine. Went and bought a new drain pump just to make sure it wasn't just the pump bad. Hooked the new one up and still no response in test mode or even in spin cycle. If anyone could help me figure this out i would be very grateful.
    Top Expert:
  • Samsung Master
  • 10,875 Answers
If your Front Load Washer Will Not Pump out the Water Check The Following
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front paneldepending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump if nothing is found inside. If no noise is heard check the pump for power. To do this remove the wire connectors and connect a voltmeter turn to a drain cycle, refer to tech sheet or service manual for proper voltage reading, usually any voltage would probally indicate a faulty pump. If no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there are no obstructions. Check your hose drain, if it is a slow drain this can cause your washer to not properly drain.,,,,,,,,,,,,,,,,
Posted on Apr 27, 2015
    Genius:
  • Samsung Master
  • 1,585 Answers
Some makers used a neutral from inter lock make a test lamp up ie bed side lamp if uve no multy meter
  • 32 Answers
SOURCE: maytag neptune mah8700aww wont drain, spin or put water in
if you remove the oval cover in the back of the mach,you will find the pump.there are 2 hose clamps to remove.usually you will find change stuck in the pump.remove the screws on the bracket that holds down the pump and you can take the entire pump out...good luck
Posted on Sep 29, 2008
  • 1550 Answers
SOURCE: Fisher Paykel GWL10US Washer won't spin
It looks like it has to be the control module.
You need to replace it .
It will cost you around $200 .
Posted on Oct 16, 2008
  • 22 Answers
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Posted on Oct 21, 2008
SOURCE: Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
  • 662 Answers
SOURCE: Error 03 not draining or going to spin cycle. Tub
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
My samsung tv LNT4669FX/XAA screen is blank but the tv and backlight work. how do i fix the tv?
It sounds like the screen may have failed, that means a new TV will be needed.
Feb 24, 2017 | Samsung Televison & Video
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
Samsung washer ND code and not drain and spin
Sounds like control Board isn't sending voltage to pump. Most likely a control issue.
Nov 03, 2017 | Samsung Washing Machines
My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
HAVE LE CODE ON SAMSUNG WF316LAS/XAA WASHER LE CODE AND BEEPS
LE is a water level issue.
- The part of the hose where the water level sensor is
located is damaged (punctured).
- The hose is clogged with foreign material.
- The hose is folded.
- Too much lubricant has been applied to the insertion
part of the air hose.
- Hose engagement error (disengaged)
- Part fault (Faulty internal soldering)
- The water level sensor terminal is disengaged.
- Main PBA fault.
Dec 19, 2009 | Samsung WF316BAC 3.79 cu.ft High...
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Washing Machines Logo
148 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
