Question about Humidifiers
What does the code EC mean?
What can I do to get humidifier working again?
My Kenmore Humidifier 15420 has a code of "cf" what does it mean?
Depending on your model, the CF could mean the filter needs to be changed or that the unit needs to be reset. If your model doesn't have a reset button, you can unplug the unit from the outlet for 5 minutes.
Jan 18, 2017 | Kenmore Humidifiers
CL error code
The CL code means that the "Control Lockout" function has been activated. This prevents the buttons from functioning. To deactivate it (re-enabling the buttons), hold down the power button for five seconds. See the manual for more info:
http://www.searspartsdirect.com/partsdirect/user-manuals/9962/758154080-Kenmore-Parts-HUMIDIFIER-manual?pathRender=fromManualTabPage
Jan 13, 2014 | Kenmore Humidifiers
My sunbeam humidifier doesn't work
Do you mean Dehumidifier? A machine that takes the humidity out of the air. If this is what you mean and you hear the fan motor working with no water dripping then the problem is that the coil which holds freon gas has leaked out the gas and can be recharged again with the leak fixed of course. Depending how old the unit is you may be better off buying a new model. Repairs can be costly. Hope this helps!
Mar 26, 2012 | Humidifiers
Humidifier what does CF stand for
It may mean "Change Filter." After you replace the filter, unplug the humidifier for 30 seconds, and then you plug it back in, the CF code should be gone.
Dec 04, 2011 | Kenmore 14410 Humidifier
How do I know it is working?
Hello, You can tell if the humidifier is working if you see water flowing into the drain line. Also , when the furnace turns on you should here a click at the solenoid valve on the humidifier, this means that the solenoid is open and letting water into the humidifier.
Jan 22, 2011 | Aprilaire 700 Humidifier
Emerson furnace is not igniting
limit switch may be stuck open.open top door on furnace switch is round with little black hose on it. disconnect hose from furnace side and **** on it to see if it will close.reconnect hose and try furnace
Dec 05, 2008 | Honeywell Power Humidifier: Furnace...
Error Code E3
I have the same type of Aprilaire humidifier unit with automatic temperature sensing control. My unit also displayed the 'E3' code. The HVAC technician was on site today and replaced the temperature sensing unit that is located outside the house. The humidifier is functioning normally once again.
Dec 03, 2008 | Aprilaire 600 Humidifier
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Feb 07, 2008 | Bionaire Warm Mist BWM0400-U Humidifier
Humidifiers Logo
271 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
