Why does my TV turn on then immediately turn off with the red indicator blinking twice at intervals?
    Top Expert:
  • Televison & ... Master
  • 42,882 Answers
The power supply may be failing.
Posted on Apr 21, 2015
5 Suggested Answers
  • 8457 Answers
SOURCE: How to fix continous red blinking lights
Ur power board supply is dead.Replaced the power supply well solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Posted on Feb 11, 2010
pjhislay1
  • 822 Answers
SOURCE: TV IS POWERING ON BUT
needs new caps on power board.................
cheers
Posted on Mar 26, 2011
jdvillanueva
  • 2098 Answers
SOURCE: TV power shut down, began
Hi garnie868,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the dried-up/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit and blinking error appear. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Secondary reason of fault is the open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 16, 2011
spr1949
  • 1182 Answers
SOURCE: TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Posted on Jul 26, 2012
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Sony Projection Televisions - HOW TO FIX TV Red Blinking light of times between 3-second intervals and turn off
I have a Sony Bravia. Smart Television that would not turn on once in standby mode. The Red light would blink twice. I unplugged the television and reconnected it using a surge protector power supply strip. This solved my issue. From now on I'll be sure to turn the television off instead of allowing it to turn itself off.
May 01, 2014 | Televison & Video
Sony TV turns off immediately after turning on
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Check this link to get more details about Sony Blinking codes.
Jan 13, 2013 | Sony FD Trinitron WEGA KV-20FS100 20" TV
My sony kdf e50 12u wont turn on red light blinks twice
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
Jun 22, 2012 | Sony Televison & Video
Default code for Sanyo GXDB remote for Sanyo TV
for sanyo tv....
1) press tv button
2) press and hold setup button till light blinks twice
3) enter code 10154 light blinks twice tv should work
Mar 31, 2012 | Sanyo 42 in. LCD TV
Sony Trinitron TV
read the answer on this page really helpfull
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Apr 01, 2010 | Sony FD Trinitron WEGA KV-27FV17 27" TV
When our garage door opens, my light turns off immediately. How do I get it to stay on for about 5 minutes?
Try this:
Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates that the timer is reset to 1 1/2 minutes. Repeat the procedure and the light will blink twice, resetting the time to 2 1/2 minutes. Repeat again for a 3 1/2 minute interval, etc. up to a maximum of four blinks and 4 1/2 minutes.
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
I got a problem in TV. TV starts and shutdown immediately, while from sound its looks like that raster is going up but no picture, no sound. Red light is blinking. This happens only when i power off the tv...
Hi Sikandar,
Let me know how many times red led blinks as there would be an interval of 3 seconds so count blinks from pause to pause.
Is it Sony AR25M61 model or any other?
Above info will help to diagnose problem.
Thanks.
Nov 13, 2009 | Sony KV-AR25M61 TV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
Top Televison & Video Experts
