Can u tell me which buttons are which please for the spin and tep no numbers on mine
I want a epos tep-160mc thermal printer drivers
Did you try http://4u-drivers.blogspot.co.uk/2013/05/reciept-printer-epos-tep-160mc.html please"
Feb 21, 2016 | Office Equipment & Supplies
Kenmore troubleshooting
Check the condenser fan. #1 problem with refrigerators. It is in the rear, low, behind the lovely cardboard panels. Try not to tear the cardboard. Duct tape will patch it, if you do.
May 30, 2017 | Dishwashers
Broke fwd/rev Button
OEM Replacement Parts DIY Repair eReplacementParts com
Should have the parts but you will need to put in the model number. That will give you a schematic from where you can get the part and also order it from them. At times they will also have a video on how to make the repair.
Feb 28, 2014 | Black & Decker 18V Cordless Drill/Driver
My danby washer model DWM99W will not drain or spin or drain out the water please tell me what the problem is
I don't have a solution but mine is doing the same thing. Sounds like the motor is running but the washer will not drain. And now it won't spin either??? HELP!
Feb 10, 2011 | Danby Washing Machines
Clock setting
Mine is a Samsung, I don't know about your brand, but mine has a "CLOCK, AUTO/START"
button. Press & hold this & punch in the numbers until have the correct time
Aug 09, 2009 | Microwave Ovens
Kenmore Elite HE5t Washer Error Code F11
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Jan 03, 2009 | Washing Machines
Subsidy code for i850
Sorry there are no subsidy codes for the i850. This means that you have used the wrong type of SIM Card. You can only use a Sprint Nextel or Boost SIM Card in an i850. If you are using a correct SIM card, you will need to have this repaired at a local service center. This is covered completely by Sprint Nextel's ESRP (Equipment Service & Repair Program) and TEP (Total Equipment Protection), and can be done at any Sprint Nextel Service & Repair Location. If you do not subscribe to ESRP or TEP, the charge for the repair will be no more than $55.
Feb 28, 2008 | Motorola Mobility i850 Cellular Phone
Dryer will not start when start button is pressed, makes a buzzing noise
open the door set the timer fo 60 min reach in while holding down the door switch give it a good spin hard clockwise and tell me what happens
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
