Question about Breville Vcf042 Wake Cup Hot Water Dispenser
I have a dim light. How do I make it brighter?
  • David Bevan
    David Bevan Apr 23, 2015
    When I bought it the light was very bright On the clock now it has gone very dim a bit like me help please
Why would the light stay on for longer than normal
Which lights are you talking about, Dome light, headlamps, taillamps? What is year--make--model?
Nov 09, 2015 | Cars & Trucks
How do you make the number that tell time light up darker so you can read it.
If you want to make the display brighter (remember, it auto dims in low light):
1. Hold down the "clock set" button while pressing the "volume" button up or down (up for brighter, down for dimmer).
Jun 10, 2014 | Bose Wave Radio
Back light dim when start up then get brighter
Normal.
When the ignition is first turned on (but before the engine is started), the light is running just off the battery, which may not be fully charged.
When you engage the starter, this is the biggest power draw there is from the battery, causing the light to dim even more.
Once engine is running (if everything is working right), the alternator powers the light, as well as everything else.
In fact, if may/may not get brighter as you rev the engine.
Feb 17, 2014 | 2010 Piaggio Typhoon 50
Dash lights
the button to reset your milage done turn that it makes the lights dimer or brighter
Jan 04, 2014 | Mercedes-Benz Cars & Trucks
I just bought new headlight bulbs but one light is way brighter then the other, my left is brighter then the right and stays dim even when i turn on the night lights. whats the issue?
dear,
There is the issue with the wattage of bulb you have got for the vehcicle.
And also due to a new bulb it shines brighter then the old one.
get the old one also repaced to get the equal brightness
thanx
May 19, 2011 | Dodge Dakota Cars & Trucks
I have a CDA 7892 alpine works great but would like the display to be brighter seems a bit dim manual does not say this model can be adjusted or am i missing it any help thanks in advance
You didn't specify if you wanted the display brighter in the daytime while headlights are off or if it is too dim when the headlights are on, with respect to the rest of the instrument panel illumination. Too bright is easier to deal with but too dim is tough. If it is always too dim under but daytime and night time conditions the only way to improve brightness would be to very gently disassemble the front panel (easier if it is the removable type) and determine what provides the back lighting. If there are tiny LEDS you could painstakingly add more LEDS or swap them out for brighter LEDS. There could be a lot of guesswork determining if this or that LED was brighter than what is in the unit as built. It may just be easier to live with it as-is.
Mar 26, 2011 | Alpine CDA-7892 CD Player
Purchased yesterday, digital lighting of numbers seems dim, can't seem to access a mode to make it brighter. How to make it brighter?
mcdevito75 here, I don"t think the brightness is adjustable, and even a new watch could have a weak battery as the light uses a lot of juice.
Sep 26, 2010 | Watches
'99 ford escort head light will dim when
The wiring harnesses in the plugs behind the bulbs are burned up seperate rear of headlight cover and inspect parts available at your ford dealer
Mar 31, 2010 | 1999 Ford Escort
Left headlight is dim - like it has a bad ground. Right is fine. DRL are same as regular lights. High and Low beam on left same dim condition. Fuses are OK switch checks OK. Replaced the relay with no...
i think you hit the nail on the head with the ground problem,if you remove the bulb from the head light assembly,wiggle the black wire to see if the bulb gets brighter,if it does remove the bulb and clean and tighten the ground wire end.if it does not get brighter from a wiggle,connect the ground end of a test light to the positive post of the battery and probe the black wire,test light should light,if so replace the light socket.
Nov 26, 2009 | 2000 Chevrolet Blazer
Cant get my light brighter. It is the same brightness as the dim
What model is it? Have you tried the dim/dark button again -some units have multi-level of dim
Apr 06, 2009 | Vehicle Parts & Accessories
Breville Vcf042 Wake Cup Hot Water Dispenser Logo
208 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
