8 months before my cpu was brakedown. that period i was not using this monitor. Today im connect new cpu and Now its displsying only quarter area of up side in the display. Other area ash colour look.
  • 5,631 Answers
Find a friend with any monitor and connect it. If looks ok, "recirculate" your bad monitor. If it's ok, probably you have some problem with your video card. If it's an on-board buy a cheap video card, inseert it in proper slot and change BIOS settin to this card.
Posted on Apr 21, 2015
  • 3,960 Answers
First, make sure you have the appropriate drivers for your monitor loaded on your computer. You may have to also change your video card settings to optimize the image.
Without knowing what make and model you are referring to, it is very difficult for the volunteer Fixya experts to focus in on the problem and then assist you.
noone
  • 105 Answers
SOURCE: White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Posted on Sep 04, 2006
shanth
  • 108 Answers
SOURCE: is it my monitor or my video card
1.there might be a problem with your signal cable. if one of the pin in the signal cable is open. it might also happens
2.adjust signal cable.
3.Check VGA video card is working properly. unplug the VGA card and Re-plug to its slot. if your mother borad has inbuilt video card. this process cannot be performed
4.Even problem with operating system might also happen.. problem with Video Ram memory
5.if you want to check whether your monitor is ok. just get Cpu Box alone frm friends for a while for a testing.
6. if your monitor have problem then contact service centre.
Posted on Dec 22, 2007
  • 109 Answers
SOURCE: LG lcd computer monitor
try to connect your old monitor and adjust your screen properties down to 800x600 with medium color setting..or go to xp safe mode, adjust screen properties to the lowest setting, xp has not yet installed the monitor driver of your lg lcd monitor.
Posted on Jun 01, 2008
SOURCE: Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
Posted on Jun 17, 2008
anjana03
  • 361 Answers
SOURCE: No Display on IBM G42 CRT Monitor's screen
if u change monitor . you came to know fault of monitor or cpu., if monitor works cpu is not woking properly..some itime we face same problem to creat by changining highgraphic. we can reduce graohic by using f8. re instiling xp we can solve that type of some problem.
Posted on Jun 15, 2009
Why is my monitor shuts down after just using it a few minutes?
This could be signal cross-talk from touching wires. Separate the wires in back.
May 07, 2014 | ASUS VE208T 20 inch LCD Monitor
The speakers on the front of my HP w17e monitor used to work, until I connected seperate speakers so I would not blow out the monitors. Today I did not plug the seperate speakers in, and I can't get...
Check the audio jack plug from monitor to cpu if connected correctly. The audio jack plug should be connected to the sound card for audio out. You can also check if the volume in the monitor is adjusted or mute
Jun 27, 2011 | HP w17e Monitor
Hp w1907 monitor does not detect any input and goes into sleep mode. checked wiring and connections -- looks normal. No trouble until today.
try to connect the monitor to another working PC, or to a laptop monitor socket, if it works there... then there is a prblem on you PC display driver or display card inside your PC, try to connect another working monitor to you trouble PC and check if that works.
Dec 07, 2009 | HP w1907 LCD Monitor
My motherboard Problems
First open cpu cabinet then pull RAM memory and pull cmos cell from motherbord for 10 minutes then when you press power button press F8 key then enter in enable vga mode .
Then go to dispaly property then change screen resolution to 1024*768 then apply and then check.
Aug 21, 2009 | ASUS P5VDC-MX Motherboard
I have a new L2210NW monitor. The serial number is 5520B82002975. I have used it for a week without any problems. Only today I turned it on and picture is faded I am using a DVI cable plugged into...
You have done all the thing I would have done and it appears your monitor is faulty. New electronic appliances can fail in the first month, and if it doesn't then they will give good service for a long period.
I suggext you get it repaired or replaced under warranty.
Aug 04, 2009 | Office Equipment & Supplies
PC Monitor and Game problem
Sounds like your dedicate video card bit the dust and you're back using the onboard video, which would absolutely be the reason why things got choppy-- it can handle the demands put on it by the games.
A new dedicated video card would fix the problems.
Jul 11, 2009 | Dell Computers & Internet
No Power to Motherboard...
Here are some steps.
Attach the monitor in your CPU and plug it, see if the monitor powers up. If it did, then no problem in your power supply,
Detach the RAM or Memory of your CPU and put it back in, in the different slot. and power up your computer.
Check the cpu power switch if it is correctly attached to the motherboard.
Oct 26, 2008 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Green shadow and low brightness in Mac Mini intel
Launch System Preferences from the ??Menu.
click on 'Displsys try changing resulution and brightness.
Nov 13, 2017 | ViewSonic VA800 17.4" Flat Panel LCD...
Is it my monitor or my video card
Oct 15, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
