Question about Whirlpool LSB6200KQ Top Load Washer
Whirlpool 9yrs old 8100 series
Noisy rattling noise then found two pins under machine, i can see where there from, but can not work out how they stay in there
  • 248 Answers
This machine comes with 2 to 3 pins installed to hold mechanism still during shipping. It has a strap out the back that you pull out that removes these. They should be out for normal operation. If one is still in, that's the problem. Also, lift back of washer about 5 inches and set back down. This locks in the legs.
Posted on Nov 15, 2007
Ecwhirlpool 8100 series 8kg. Agitator spinning one way at same speed so all clothes get all twisted together.
is this washer old? im not familar with that series ive got no tech manuals on it, if it is old it will be a small grey box under the display panel with two or three wires coming out of it, this box is basically a simple triac switch that switches between two points to make the motor change direction if the agitator only goes one way one of the switch points is damaged unfortunately these boxes are completely sealed with silcone so repairs to the switch arnt possible, if u can track down a second part you shud be right
Jul 06, 2011 | Whirlpool Washing Machines
Noisy on spin cycle "rattling"
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi, my AWM 1200 is 9yrs old but still washes and
Your machine most probably has had water in the spin bearing. The seal has worn and allowed water to rust the ball bearings which are no longer smooth...Hence the noise! A fairly major job which could also need a new shaft and inner drum. Get quotes, but be prepaired. Too much detergent can also speed up seal failure......Good luck....Nomess
May 13, 2010 | Washing Machines
Noise when the drum turns.
Hello, I have the same issue with a machine now 5.5 years old. At lower drum rotating speeds, a loud clicking (almost stripping sound) is heard. I have only inspected from the lower front cover and found nothing. Will also look in the back for clues...
Dec 30, 2009 | Whirlpool Washing Machines
97 buick park avenue 3800 motor making a noise in the top end but sounds like a knock but hasnt effected the performance of the car just noisy
It is probably a noisy wrist pin on one cylinder,
also known as "a death rattle"
GM had this in their 2.2 engines,
Dec 16, 2009 | 1997 Buick Park Avenue
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Motor makes loud rattling noise during rinse cycle
could be the coupler and the only way to truely check it is to take the pump, then the motor off. But it seems strange to me that you say it works fine. Is it spinning? usually when the coupler breaks it sounds horrible and usually will not spin but it will drain.I would check the coupler again.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Kenmore dryer king size capacity 90 series
Sorry to say, but the motor needs to be replaced. motor cost around $150... 9yrs old=not worth fixing...
Jan 03, 2008 | Kenmore 63942 Dryer
Whirlpool LSB6200KQ Top Load Washer Logo
189 people viewed this question
Dan Webster
Dan Webster
Sal De
