Question about Health & Beauty
Hello, I have a Freerider Kensington 4mph scooter, it all lights up but wont run. Ive test power to the controller, 24v going in but not power from the Rhino controller plug to the motor but power going out to the brake
  • Phil Duffy
    Phil Duffy Apr 21, 2015
    Hello, thanks for the user manual link. It shows no flash code errors, brushes looks nice and long, all plugs are connected. I am getting 245v to the brake without pressing the wig wag an no voltage from the controller to the motor even with the wig wag pressed.
    Top Expert:
  • 10,875 Answers
I bought a pride wrangler mobility scooter. Did not move could hear a click coming from left motor. took right motor off and tore it down. It was all glazed over.
If two 24v batteries are the standard fitment it isn't likely it would be fitted with a 36v motor - unless some bright person fitted the wrong one...
I am not sure what you mean by "glazed over" unless it is the commutator you refer to? A commutator made from quality materials and fitted with brushes made from the correct grade of carbon or copper/carbon and being run at approx. the correct voltage is likely to become well polished and may become carbon black in colour but that is without detriment.
It is permissible to clean the commutator. I find spinning the armature in a drill and using a fine emery cloth is adequate.
Once reassembled the motor can be connected directly to 24 volts for testing.
Nov 06, 2016 | Pride Health & Beauty
Freerider mobility scooter
hi, okay there two things the batteries and the charger, can you try another charger ?
1. Batteries need replacing ?? make sure battery terminal connections are tight.
2. How long are you charging the batteries for ? i hear you say that's a silly question however you be surprised how many people charge their batteries for a hour then remove the charger.
3. Is the charger faulty ?
4. there is a remote possibility of a controller fault however this is not common..
In relation to the charger if you're in the UK, I offer a free testing service , you only pay the return postage...
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Health & Beauty
E100 scooter wont run. Battery fully charged, 24v across terminals. Motor runs fine when connected directly to battery power. On-off power switch, breaker switch, brake unit switch, accelerator all checked...
It is possible the new controller is defective, however just because the voltage is showing 24v it may not be outputting the correct amount of amps so don not rule out batteries before checking the following:
To test a battery you need to 'load test' so (with help) connect the battery directly to the motor when weight is on the scooter to see if it will still pull.
Please also remember that you do have to push the e100 to 3mph before starting (many users do not know or forget this step)
Jul 04, 2011 | Razor E100 Electric Scooter
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Missing manual Do you know where I can get a manual for Freerider Kensington mobility scooter thanks Dianne
I need a manual and wiring diagram for a electric mobility mobility electric power scooter wheelchair model chauffeur 230
Jul 01, 2010 | Electric Mobility Mobility Electric Power...
Freerider mayfair, no life at all in scooter
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Sep 30, 2009 | Health & Beauty
Does the Freerider kensington have oil in the drive motor? if so how do I check it and what type and quanity does is it use? Also does anyone have a workshop manual for this
No Oil but you do have a grease nibble located on top of the gearbox, get hold of a grease gun and give it three squits of grease.
Regards
GeWiz.
Mar 15, 2009 | Health & Beauty
Health & Beauty Logo
164 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
