Question about Brother MFC-J5910DW Color Inkjet All-in-One Printer
Magenta ink not detected even though new cartridge
Copier will not print at all
    Top Expert:
  • Brother Master
  • 6,702 Answers
When replacing a cartridge also check the contacts on the cartridge and in the printer. They should be clean and shiny. One spec of dust can spoil the fun. When the contacts are clear an the next cartridge is having the same issue it could be the printer has a cable or contact issue, or even the logic board can be defect.
Posted on Apr 21, 2015
HP CM1015 - stil works; Magenta does not print even though full
The magenta might have been freezed, change the magenta.
Thanks.
Jun 19, 2012 | HP LaserJet CM1017 MFP All-In-One Color...
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I have a HP 7580 printer/fax/scanner which will not print in black even though i have installed a new black ink cartridge
I had this same problem, replaced all ink cartridges and problem still remained. The fix for this is actually to replace the print heads not the cartridges. There is a black/yellow and Magenta/Cyan print head in the printer itself under the scanner on the right hand side. Rpelace as needed.
Nov 02, 2009 | HP Office Equipment & Supplies
Why is it that my printer won't work if one ink cartridge is empt
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Mar 31, 2009 | Epson Stylus CX7000F All-In-One InkJet...
Can I print "Black only on the Epson BX 300 F ?
Since the printer insists on having all 4 cartridges (non-empty) fitted before it will print anything, the only recourse to fitting new cartridges is to fool the printer into thinking your empty magenta cartridge has ink in it. You can do this by using a cartridge resetting tool to reset the magenta cartridge chip so it reads "full". A resetter tool can be obtained from e-bay very cheaply (£4 or less). You will find sellers who ship worldwide on E-Bay UK.
Be aware though, that if you forget to select monochrome printing, the colour ink is also used in black printing - and printing with a "dry" cartridge can damage the print head. You can guard against this by filling your magenta cartridge with distilled water.
You will also find sellers of magenta cartridges (and the others of course) on E-Bay UK who ship worldwide.
Feb 25, 2009 | Epson Stylus C86 InkJet Printer
Canon Pixma 4500 when printing on photo paper there is a Magenta cast over the print, even on black and white prints
the Magenta ink cartridge is leaking. replace with a new one.
clean the ink cradle before insert eh new one.
Nov 12, 2008 | Canon Office Equipment & Supplies
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother MFC-J5910DW Color Inkjet All-in-One Printer Logo
47 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
