Question about Samsung Dishwashers
When I start my dishwasher it start to run then it stop and flashes se code what causes that
    Top Expert:
  • Samsung Master
  • 10,875 Answers
Drain problem Check drain hoses
Replace drain pump
Posted on Apr 21, 2015
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
How to fix samsung dishwasher code se
The code is 5E
Apr 21, 2015 | Samsung Dishwashers
Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
Jan 10, 2015 | Samsung Dishwashers
FDB4315LFC2 runs then stops and flashes pf ?
Good Morning Friend,
I understand that your Frigidaire dishwasher, model# FDB4315LFC2, starts and then stops, and flashes a "PF" code when it stops. The "PF" code is stating that there has been a power failure. There could be a possibility that your dishwasher is losing power mid-cycle. I suggest checking your home's circuit breaker, the wiring to your dishwasher, and if you have a cut-off switch, checking that as well. I also suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I have a newer Samsung dishwasher and a Code SE is flashing what does this mean
I have a Samsung dmr77 dishwasher and the code SE is coming on and it doesnt sound like there is water coming in the dishwasher. What does this code mean?
Feb 12, 2011 | Dishwashers
SE error code on Samsung dishwasher - ...any suggestions?
This means that the Dishwashers has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the Dishwashers off and on again.
If you still see the "
SE error code," turn off the power to your Dishwashers and wait five minutes before turning it on again. If you hear the beep or see the "SE error code" when you try to washing again, please call your authorized provider for service.
Hope this help?.
thanks for visit.
Dec 15, 2010 | Samsung 24 in. DB3710D Dishwasher
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
My whirpool dishwasher clean button is flashing.
Does the clean button flash 7 times then repeat... if it does you have a heat problem,, you will need to run diagnostics to clear the code and or find the problem.. let me know I can help
Sep 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
618 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
