Machine stars showing error e000002
How to fix this problem?
5 Suggested Answers
SOURCE: when i switch on the machine,error E000002 is comming
E00002 on iR3300 is problem on the heater assembly. Replace heater assembly and buy new heater assembly. Good Luck...!?
Posted on Feb 06, 2009
canontech
  • 1219 Answers
SOURCE: error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Posted on Mar 03, 2010
Cogz
  • 1326 Answers
SOURCE: ERROR CODE E000002-0000
The error code means the fuser is not warming up or is not turning "ON" . Have you had a power surge recently? To reset it you have to go to service mode... To get in press these bottons on the control panel as follows > "*" then the numbers "2&8" at the same time then the "*"... The display will change then press "COPIER" Funcation > CLR (2nd collum) > ERR > then press "OK" in the bottom right corner. Then press the Reset key twice and turn the main power switch OFF on the right side and then back ON... If the code will not clear you have a bigger problem. Good Luck
Posted on Apr 25, 2010
canontech
  • 1219 Answers
SOURCE: Machine show an error E000002 Model iR2530 Canon
these means the reading of the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has indicated 100
deg C.
2.The reading of the main thermistor is less than 150 deg C
continuously for 400 msec 1.3 sec after it has indicated 140
deg C.
Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON the
power.
TO ENTER SERVICE MODE:
press *
press 2
press 8
press *
If you cant clear the error code these means that you need to replace fixing heater.
Hope that helps!
Posted on Aug 19, 2010
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
Why is it displaying error code E000002-0000?
Check this link for explanation
Error E000002 0000 on printer
or here:
Thread canon IR 2200 error code E000002 0000
or put into Google: E000002-0000 - which is what I did.
Feb 14, 2015 | Office Equipment & Supplies
How to solve error code of E000002-0000
The problem is in temperature of a fixing film.Try to clean the heater,put on the grease...If ther's still a problem,replace the heater
Sep 23, 2014 | Canon Ir 3300 Black & White Copier
How i fixes error code e000002 i change new fuesr unite but the error code is not remove pleas help how to solve?
http://www.copytechnet.com/forums/canon/5317-canon-ir-2200-error-code-e000002-0000-a.html
Aug 10, 2014 | Canon Ir 2525 Copier new
Clear E000002-0000 on canon ir 2200
Press the usermode star and release and then no 2 and 8 togheter and relealese,press the usermode star again.The machine will go in to service mode.Select copier and then on the next screen select funcktion and then clear.press the error and select ok.Switch the machine off for a minute and on again.The machine should be ok.After the clear has been done and the error is still showing then the fixing unit is faulty.
Dec 12, 2009 | Canon imageRUNNER 2200
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
When i switch on the machine,error E000002 is comming
Feb 06, 2009 | Canon Office Equipment & Supplies
jasbo
jasbo
