Question about Stainless Washing Machines
Took out agitator. Took off top covering. How do I take out inner stainless bowl
  • Stainless Master
  • 5,323 Answers
TAKES A SPECIAL TOOL CALLED A SPANNER WRENCH ITS ABOUT 1 INCH AND 11 /16 IT TURNS OR REMOVES CLOCKWISE NOT COUNTER CLOCKWISE
Posted on May 08, 2015
Fisher-paykel GW712-AU
unplug. remove lid by opening and bumping to one side. two screws at front of machine under rubber covers. lift top gently, remove bowl ring, 8 clips and one spring. unscrew agitator. you can now remove the inner bowl and clean. theres not filters in this machine.
Dec 04, 2013 | Fisher and Paykel Washing Machines
IWL16 mildew or black specks on clothers
could just need a good clean. these machines remove dirt from clothes very well, but it can build up on the inside of the outer. disconnect power, remove top (two screws under covers under lid), remove top bowl ring (8 clips) remove agitator (1 screw deep inside) remove inner bowl. scrub it. also trying a hot wash with some cleaning product to flush the machine every couple months can stop this happening in the future.
Nov 10, 2013 | Fisher Paykel EcoSmart GWL15
My simpson esprit 450 washes dirt/sand into the tub - how can I clean the
Hi just read your posting.The only way you can assess the tank is to remove the inner bowl.This is quite difficult.I can help you with removing the inner bowl but I think the easiest way is to fill the machine on a High water level and when it stops filling and starts to agitate pause the machine and advance the cycle to spin and let the pump drain out the sandy water.Give this a try the reply back on how you got on.
Jul 14, 2012 | Washing Machines
How do I remove the drum on my aav7000aww
To remove the inner tub
remove front panel
remove screws holding top to cabinet
raise top
remove hoses from tub cover
remove tub cover
remove agitator
remove bolts holding inner tub to hub. 5-6 hex head bolts
lift off inner tub
Aug 20, 2011 | Maytag Washing Machines
Fault code 40 on fisher paykel washing machine
Hi -
Code 40 - is Bowl Fault
The electronics has sensed that the bowl is not engaged.
Check the following - Mechanical.
1. Check that there are no foreign objects causing the bowl to malfunction. As it fills up the inner bowl will disengage from the outer bowl. It will sort of freewheel as so to speak.
2. If empty of water, carry out a clutch disassembly procedure and check spline drive. - removed center of agitator, unscrew middle of the agitator a screw, remove the screws on the top pf the inner bowl to separate, will need to remove the top though to do this, usally two rubber bungs on the front screws under and the rear is normally plastic clipped/lock setup.
3. Next check that the pressure tube has not come off and that it is not kinked. - check the clear tube by blwing into the bowl as you remove the top electronics cover (2) screws top rear - do not blow into transducer on the controller module.
Electronics - if all else fails - Replace Motor Control Module.
Jun 12, 2011 | Fisher and Paykel GWL11 Top Load Washer
How to clean pump from fisher & pkal smart drive 708
FIRST - remove plug from wall, then open lid and remove the rubber bungs that the front of the lid sits on, under them is 2 screws, remove them. Lift the complete upper plastic portion and rotate back against the wall. Remove the screw from inside the agitator and remove the agitator completly. Remove the bowl top cover by unclipping it from around the outer edge all the way round, note the spring position for refitting, lift out the bowl top cover and set aside. Remove bowl, can be tricky but it should lift right out. With the bowl removed, remove the large phillips screw from the plastic cover over the pump, with the screw removed, the pump cover will pull out (up) and the pump can be cleaned out.
Make sure that you clean out the channels that the water flows through around the pump impellor. refit the pump cover, ensure the rubber ring is in correct position, and secure with the screw. Reassemble in reverse order.
Test the pump for operation before doing a full load.
Mar 02, 2011 | Fisher and Paykel Fisher & Paykel Washer
How do you remove inner tub to get to the outer tub of Fisher & Paykel gwl11
You need 2 people for this.. Unscrew plastic wingnut down the centre of the agitator.(2) undo 2 phillips head screws under little rubber covers just under lid at front top edge.(3)lift top of machine like a car bonnet,get someone to hold it up for you.(4)Unclip big round plastic ring on top of the bowl,you may find its attached with a spring at the front left hand corner,just lay the plastic ring over front of machine & let it hang.The bowl should just lift straight out.Be carefull,the outside of the metal bowl is like a cheese greater trust me! PS when you put it back together & you lower the top of the machine(make sure that little white plastic lever hanging down) the right hand rear go's outside the righthand rear of the tub NOT squashed on top.Its an out of balance lever & it needs to dangle outside of the bowl/tub right rear.GOOD LUCK!
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
How to clean Zojirushi NS-MYC 18 rice cooker
I just took my lid apart on my rice cooker. My suggestion for dealing with the dirty stainless steel cover under the vent hole is to not look at it! The lid is not designed to come apart. I had to pry the top cover off of the lid. Once again just don't look in the vent hole and everything will be fine. (sorry about the bold letters my bold got stuck.) Have fun with the yuck in the vent hole.
Nov 01, 2009 | Zojirushi NS-MYC18 Neuro Fuzzy 10-Cup Rice...
Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Maytag LAT3600A Top Load Washer
LEAKS AND SQUEAKS
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Mar 24, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Stainless Washing Machines Experts
Thomas Perkins
Thomas Perkins
Jorge Rendon
Jorge Rendon
Are you a Stainless Washing Machine Expert? Answer questions, earn points and help others
