Question about Ovens
Oven timer is reading P0:00 error message. What can we do to fix this?
Tried switching the oven on and off at the wall switch.
  • Melissah Zalunardo
    Melissah Zalunardo Apr 23, 2015
    The oven works ok the display of the timer will not change so we can set the clock or timer I have switched it off at the power switch it didn't make any difference
    Oven model is 00971XA. Big 90 oven range by omega
    Top Expert:
  • Ovens Master
  • 48,497 Answers
Sorry but without make and model we have no idea where to begin looking .
Posted on Apr 23, 2015
I have a brand new Viking french door oven...Went to set it at 450 on bake setting and got an F02 error code. How do I fix this?
Fault F02 is indicating an overheat fault- service manual says to replace main electronic control board.
Sometimes switching off at wall will clear the fault.
However, switching off at wall will reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears. Good luck!!
Oct 05, 2017 | Viking Ovens
How do I set the timer on the EOG9330XN oven
If the oven is switched off on the wall or there is a loss of power, the clock will stop and you will not be able to use the oven. This also applies when you switch on oven for the first time.
Always you have first to set the time of day, then is possible to turn on the oven. Read user manual.
Dado
Oct 09, 2014 | Electrolux EOG9330 Gas Double Oven
Magnetron fan runs all the time
The timer that runs the mag is stuck. Unplug fan for 30 seconds and check it out. If not fixed, then look at replacing if microwave is older 7-8 years old.
Feb 24, 2013 | GE JKP90SPSS 27" Microwave Combination...
My built in Whirlpool oven is locked and it will not let me unlock it, it is showing an E1 F5 error. I have tried unhooking it from the power source and a few other troubleshooting tips I found off the...
I unplugged the range from the wall and using my meter, did a continuity check of the latch position switch (the one on the right). The switch was reading as an open circuit in standby and when I actuated the switch which tells me the switch has failed. The second switch on the latch assembly, by the way, is to turn the oven light off during the self cleaning cycle to protect the bulb. That way, if you leave the light switch on the control panel turned to the on position, that second switch will turn it back off. Good to know if you can't figure out why the oven light won't turn on.
Mar 19, 2011 | Whirlpool RBS305PDS Electric Single Oven
Hi - I have a whirlpool gold series electric double oven. The error message is E1 F2. Anyone know how to fix this?
it could be the following
Taking a Quick Look
The E1 F2 error message indicates the control board thinks the touch panel has been unplugged from the board or it cannot read the switches.
How it Works
The panels on these ovens utilizes a switching matrix to constantly monitor all the buttons for a key press. By using a matrix for switch input, many buttons can be read by the processor using very few wires. The unfortunate side of a switch matrix is if any one wire becomes damaged, an entire row of switches on the matrix will no longer be usable since they cannot be seen by the control board.
advise
getting a qualified engineer to check this touch panel and suspect touch panel maybe defective and need replacing.
I hope this was helpful
Jan 05, 2011 | Whirlpool RBD305PD Electric Double Oven
My dacor oven light won't go off & the error message says close the door but the oven door is already closed. this is occurring only in the top oven.
Sorry to read about your problem, I hope this helps you out.
you have a defective door switch
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Dacor Ovens
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
Over door locked
Error code F93 means the lock motor assembly spent too much time to lock. Someone needs to read the continuity of the lock switches and the door switch and apply 120 volts ac to the lock motor to see if it will run. If the oven is less than 1 year old you should schedule service and let a technician diagnose and repair the problem. If you want to repair the oven yourself make the checks with a volt/ohm meter and send another email if you need more advice.
Dec 17, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
231 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
