Question about Sewing Machines
Trying to re-assemble the tension mechanism but I don't know the order in which the components should be assembled. Have 'Googled it but cannot find the answer
    New Friend:
  • 28 Answers
Does the machine have a make and model number?
Posted on Apr 22, 2015
Testimonial: "Thanks Mike but I don't need thread for a machine I cant use !!!"
How to thread it and how to replace the spring on the tensioner
1. It always goes in this order: tension, take up arm, needle arm, needle.
2. In between this order there are guides to feed the thread through.
3. Attached is a general guide how tensions are assembled.
4. The main thing to remember is you are trying to get the tension disc with skinny ends towards each other. This is where your thread will go in order for "tension" to be created on your thread.
5. The check spring has to be pushed in at the right area in order for pressure to be made. This is a test type area. However, you pull it out and push it back in until you feel it is right.
Sep 08, 2015 | Brother Sewing Machines
What can I do to wind my bobbin tighter
Make certain you are passing the thread through the tension for the bobbin winder when setting up to wind the bobbin. Check that tension assembly for anything that could be stuck in it, preventing the assembly from putting tension on your thread, such as another thread. Wiggle the disc on the assembly to make sure it isn't stuck. If none of that works, disassemble that assembly from the top of the machine (NOT the tension you use when threading to sew!) and see if the spring inside is broken. If it is, replace the spring if you can get it, or the whole assembly if you cannot.
Apr 28, 2012 | Brother LS-2125 Mechanical Sewing Machine
Problems with thread tension.Cant grt any tension
It's probably assembled ok. If you're trying to adjust the tension with the pressure foot up, it won't work. The pressure foot needs to be down in order to adjust the tension.
Let me know if this works, ok?
Jan 31, 2010 | Sewing Machines
Tension assembly diagram needed.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_4526_4528_4530_threading.htm
If you go to this site, you can find some pictures and buy a manual fo around 10.00, the manual should have the pictures of the tension in each piece.
hope this helps
moni
Sep 24, 2009 | Singer Sewing Machines
Took apart tension button on sewing machine
This could be tricky, look on line for a diagram of a typical tension assembly. There aren't that many parts but they can be put on in the wrong order. There is probably a set screw somewhere that has vibrated loose, you need to tighten it after replacing the unit.
Jan 29, 2009 | Janome 2049LX Mechanical Sewing Machine
Singer Starlet 353 Thread tension
you need to do a tension assembly check.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air. The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Nov 07, 2008 | Singer 7462 Mechanical Sewing Machine
Stitching a mess
Either the thread is not in the tension assembly, the tension is not adjusted high enough or the thread is not in the take up assembly.
It's possible you have the wrong bobbin in the machine.
sewman7
May 20, 2008 | Singer 6038 Mechanical Sewing Machine
My singer simple
tension issue,,,,,upper tension assembly needs to be adjusted, either the machine is not being threaded correctly or tension assembly is bad,,,
Jan 01, 2008 | Singer 3116 Simple
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
