Question about ASUS Tablets & eReaders
My connection point for the charger on my Asus K17 memo tablet won't work and I can't charge my tablet can you help
  • 22 Answers
SOURCE: Coby Kryos Android Tablet
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
Posted on May 21, 2013
  • 183 Answers
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Posted on Oct 30, 2013
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
jasonnashjlu
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Posted on Nov 09, 2013
  • 884 Answers
SOURCE: how can I make my tablet charge when it doesn't charge with its charger
Hi
I don't know what connectors you have on your tablet, but often there is a micro USB socket for connecting a lead from there to a standard USB socket on a computer. Some devices can also charge through this connection, so this is worth a try.
You may also try replacing the charger with a new one, in case yours has become faulty (you could check for a voltage at the plug for the tablet when the charger is plugged in by using a suitable multimeter on the right setting. Absence of voltage here would confirm a faulty charger.)
Otherwise, if the charger is OK and all the connections are firm and good, it may be necessary to replace the battery as rechargeable batteries do have a finite life.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 22, 2014
  • 4 Answers
SOURCE: I just purchased the android tablet and the charger is not working, I am using my phone charger to charge it, is there a way you can send me a new charger and also I need a stylist for it. Thank you.
Hi Patricia,
Every branded Mobile Phone or Tablet comes with a warranty and the accessories along with it comes with a replacement warranty within a certain limit of time. Why dont you go to their service centre and get the charger replaced if it has a technical or manufacturing defect. If the charger is still in warranty, you should be able to get it replaced provided it hasnt been physically damaged. Good luck !
Posted on Jan 03, 2015
Why does the battery in my Asus memo pad hd 7 overheat?
You should be very careful charging any battery that heats up to the point that seems like it is overheating. Newer batteries are lithium ion or polymer and can cause fires when they get too hot although the polymer is supposed to be less susceptible. You should get a new battery if you're sure you're using the correct charger made for your device.
Dec 01, 2014 | ASUS Tablets & eReaders
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Apr 01, 2014 | ASUS MeMO Pad HD 7
My asus memo 7 inch tablet won't power up
This is a common problem with Asus devices. If the battery has drained completely, they don't like to come back to life.
Plug it in and leave it for a minute or so. Unplug the device, replug it, and hit the power button. The battery logo should appear, indicating that the device is powered off and connected to a charger. Now that the computer is awake (to display the message), hold the power button until the device powers up. You may have to hold the button down for up to 45 seconds.
Mar 31, 2014 | ASUS MeMO Pad ME172V-A1-PK 7-Inch 16 GB...
Black Screen no battery picture
If you are having this problem with the tablet, but the charger works fine with the cellphone, then mKe sure that you are using the right charger for the tablet, or it could be that the charging port in the tablet is damage, or the battery needs to be replace.
Mar 20, 2014 | ASUS MeMO Pad HD 7
Asus memo wont chrge
You just need a new charger
Feb 22, 2014 | ASUS MeMO Pad HD 7
Will not turn on
check the voly out in you vcd adapter if this exist go to open you pad and rebulding soldering the conector volt in and then ready you pad work again please vote
Dec 03, 2013 | ASUS MeMO Pad HD 7
I have an Asus Memo Pad HD 7 which I purchased 3 months ago. It worked wonderfully until one evening while using the pad plugged into the wall, it stopped showing the charge icon in the upper left hand...
Oct 30, 2013 | Tablets & eReaders
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
Tablets & eReaders Logo
42 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
