Question about Asko Dishwashers
Wiring diagram for ASKO 1605 dishwasher
1605 wiring guide
3 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: ASKO 1605 Dishwasher instruction manual
Hello & Welcome to FixYa
You can download the manual for your Asko unit here. Please get back to me if you have any other questions.
Kevin
Posted on May 14, 2011
  • 842 Answers
SOURCE: on the front panel there
HI,
No is the answer to your question. The heater circuit does not run through the door panel, thats only a safety ground so you don't get shocked if something goes wrong. I would look into the heater circuit to solve this problem. Asko directly can help you and possible walk you through this problem. Some of the problems were know to be in the control board, others were in the heater itself. 1-800-966-2756 is Asko's direct number. I am a servicer and this is the number I use. I would like to direct you in the correct direction but there are a couple of things that would be needed to fix this problem and without seeing the unit it becomes a cat and mouse game.
Can them for the correct answers, If you have problems there, I would be glad to help the best I can with manuals or parts needed.
Good Luck
Posted on Aug 19, 2011
Testimonial: "Thankyou, I was just hopefull of it been something simple :-)"
Asko dw 1605
Yes the interlock would be from the door switch.
Check out item 607 in this assembly schematic.http://spares.bigwarehouse.com.au/images/files/28918_89d4bf910be7ebd72640c42c10f0eec5.png
Apr 15, 2014 | Dishwashers
Need wireing diagram for ASKO 1385 SS Dishwasher
My best guess is this; the white and brown are hot(brown) and neutral (white), so they connect to the 2 posts that are parallel to one another. The yellow-green is ground - that connects to the center terminal.
Apr 10, 2014 | Asko 1385 Dishwasher
On the front panel there is a wire unplugged, there is a spot for it, just wondering if that could be why it blows the circuit breaker when in heat cycle. Asko 1605 dishwasher
HI,
Good Luck
Aug 19, 2011 | Dishwashers
Kevin
May 14, 2011 | Asko Dishwashers
Manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Apr 24, 2010 | Dishwashers
How do I remove the cerculation pump on an asko asko Dishwasher D 1716
Hello, With the right technique it isn't too bad, but it does require removing it from the cabinet/cupboard. This is what I do. FIRST**Turn off the power at the main service panel or unplug the unit.** Shut off the water and undo the water supply and drain hose. Remove as much water from the sump well as possible because you'll need to lye the dishwasher on its front ( remove any dishes inside and also get some towels or a blanket to lay it on so you don't damage the front panel or control's ). Once you have the unit out and face down, you'll see the back of the circulation motor&pump assembly...this is where it gets a little tricky, but I've done plenty and will guide you through. The clamps holding the pump hoses in place are "one time" clamps so once removed they'll need to be replaced with narrow "worm gear" clamps when installing the new pump assy. Undo the wires at the side of the motor ( A good idea would be to take a picture or draw a diagram, the picture is likely better...in my case at least ). Hopefully from here you will get the new one in. Let me know how you make out, I'll watch your post. Good luck. Macmarkus :)
Apr 22, 2010 | Asko D1716 Built-in Dishwasher
New install; where to hook up old wiring/plug to ASKO
There should be an installers/repair guide folded up behind the front panel. Check for that as it will show a wireing diagram. I won't be able to get any info until Jan 2. Let me know what you find.
Jan 01, 2009 | Asko D1976 Built-in Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
1502 NO POWER TO PANEL
The wiring diagram is INSIDE the metal casing behind the lower kick panel. It is a paper schematic that details the wiring of the dishwasher. Mine was pretty water logged and crusty. Just unscrew the kick panel. It should be right behind it
BTW: Ours also lost power to the panel last week. It's interesting that the production date of our Asko is from 1988. Exactly 20 years. Asko's warranty is also exactly 20 years. Coincidence? Don't bother trying to replace the board. Asko discontinued it and it is no longer available.
May 18, 2008 | Asko Dishwashers
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Apr 23, 2008 | Dishwashers
Dishwashers Logo
62 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
