Question about Sharp Office Equipment & Supplies
My machine sharp ar-m 155 is giving me e7-16 what do I do.
  • 61 Answers
HI,
According to my book, E7-16 doesn't exist, are you sure it is the right code?
Cheers
Andy
Posted on Apr 24, 2015
  • 208 Answers
SOURCE: Driver for sharp ar 5316 driver for my RHEL 5 machine
You can also go to Xerox.com and select support and downloads.
Type in WCP215 it is the same driver.
Posted on Dec 20, 2007
  • 117 Answers
SOURCE: Sharp AR-155 digital copier code H 4
An H4 code on a sharp copier inicates a problem with the heat lamp.Often a bad lamp, sometimes a thermal fuse.You should call a copier service technician.There are lethal voltages in this machine.Good Luck!
Posted on Apr 02, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
M2Tech1
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Sharp Photo Copier AR 5316
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
Posted on Jul 31, 2010
Testimonial: "than u sir every time i had problem u are helping me sir thank you so much sir"
What is system error L 100.
L1-00 means that the scanner (the thing under the glass that scans your document) needs to be replaced. Requires a technician to fix it.
May 07, 2014 | Sharp AR-150/150N/155/155N/F151...
Driver
http://support.sharp.net.au/drivers/, you can use ar151,AR-155 or ar-156 any of this driveres , rate this and vote for this
May 14, 2011 | Sharp AR-153E Copier
Olivety
F2 means that an improper cartridge has been installed. Look for the exact type that you used before and it will work.
Mar 26, 2010 | Sharp AR-5320 Black and White Copier
Copier
The problem is that the toner sensor is not recognizing that type of toner. All toner is not the same you will cause more damage to the machine. Use the specified manufacturer toner.
It display
Check the white area of document glass and clean it or the copy lamp is not lighting.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Driver of the sharp printer AR 5316E for vista 64 bits
Currently Sharp does not have any specific drivers for this model that are compatible with vista. But if you go to www.sharpusa.com under customer support, product downloads. You might try using the AR-M160 drivers. They are practically the same machine. For the model choose model not listed and manually type in AR-M160.
Oct 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5320 foud code F 7
Hello sir;E7 that' means this machine laser unit have problem, remove it send it to shop for repair.
May 14, 2009 | Sharp AR-5320 Black and White Copier
Apr 02, 2009 | Sharp Office Equipment & Supplies
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
