Put a wash on and it stopped half way through, stain buster and 90 min buttons flashing, door wont open and I have wet clothes in machine
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Drain via outlet hose also check pump for blockage
Posted on Apr 26, 2015
Tip
Allways clean your filter on your washer
by cleaning your pump filter at leased once a month will make your washer perform better and last longer. it will stop problems accuring such as (door will not open ) (the machine will not spin on final spin ) (wet cloths) (un even loads) (dirty cloths) (smell & mould ) another good tip is dry off the rubber door seal after use and sprinkle a little talk powder on it this will stop it staining with mould.
on Nov 06, 2011 | Hotpoint Washing Machines
Wont drain with a load, but will drain when empty. Have cleaned filter, have run drain cycle with filter open motors works. have filled using start of 32 min cycle, and emptied using drain, at l
sounds like inside the drum a dog waste bag or a small plastic bag for something plastic has melted onto the heating element
this can be removed for checking not easy bit fiddly but at least you can rule it out
ah you think i didnt have plastic in my wash
got kids?? then the soap drawer is the place all dirty things go to get washed
sounds like some plastic flapping about above the drum drain port
Nov 28, 2014 | Candy Washing Machines
Candy error e05
may need to replace the ntc or they come with the wash heater unit
Jan 13, 2014 | Washing Machines
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Dec 23, 2009 | Candy Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
