The insert key is not working and there is no indication for numlock,inster,caps lock
  • 113 Answers
Change the keyboard.
Posted on Apr 21, 2015
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 08, 2012 | Computers & Internet
CAP LOCK STUCK
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Oct 09, 2012 | Computers & Internet
Toshiba satellite c655d-5332 keys problem
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Sep 23, 2012 | Toshiba NB205-N210 Netbook
Please help. The 789uiopjkl;m./ keys have keypad numerals on the front bevel. when I try to type "uio" for example I get "456" and "jkl" gives me "123". To get the...
The number lock feature is enabled. You should see an indicator for the Num Lock (lit when on) that is next to the Caps Lock indicator.
You should be able to disable the lock by pressing Fn and Num Lock together on the keyboard. (On some Sony Vaio keyboards, type CTRL+ALT+NumLock or Shift+NumLock.) The number lock should be at the top of the keyboard near the F1-F12 keys. Sometimes the key is shared with the Scroll Lock function (otherwise it will be nearby). It's really easy for the Number lock to be enabled on some Sony keyboards; just some dirt between the keys can enable it when you didn't turn it on intentionally.
I hope this helps.
(I don't have the VGP-WKB1 wireless Sony keyboard and can't find a good picture of it to find the Num Lock key for this model.)
Jul 08, 2011 | Sony VAIO VGP-WKB1 Keyboard
Asus netbook type letters it put numbers
This issue is due to you having activated the "Number Lock" function of your keyboard !
To revert to full keybaord function:
Press Fn+NumLock. The numLock shares it's key with Insert
Note: Fn key is the Blue Key at the base left of the Keyboard.
May 08, 2011 | ASUS 90-A4C1K1000 Keyboard
Do any of the current Logitech Keyboards have an led on the numlock key??
Not on their wireless products (uses battery power), but you can download this handy litttle app that shows the CAPS,NUM,and SCROLL LOCK status on the screen. It also gives audible feedback when typing in all caps and when the status is changed.
http://download.cnet.com/NumCapsScroll-Indicator/3000-2072_4-10604212.html
Jan 12, 2011 | Logitech 967437-0403 Keyboard
When I write text on the laptop keyboard, only numbers show but no letters. what to do?
Try reset your laptop. Remove the battery and allow 1 hour before re-inserting the battery. Then get back to me what happen.
Nov 04, 2010 | IBM Thinkpad 560 Series Laptop 20h4241...
When i press a key with a letter and a number the n4mber appear. i have to press fn for the letterns to work
press Fn+ numlock key for some laptop its F8. that will disable the number lock. thanks
Mar 28, 2010 | Lenovo ThinkPad T61 Notebook
SHIFT LOCKED ON
There should be a function key that is a light blue on the lower left. Hold that down and hit the NUM lock key at the upper right.
What happened is that you turned the numlock on just like on a regular keyboard but on a laptop, its a secondary function key where the letters double as numbers when the function numlock is turned on.
give it a try and let me know.
Good luck
Feb 15, 2009 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
