Question about Thermador Cooktops
Where to buy wires connecting the ignition assembly to reigniter unit for THERMADOR gas cooktop ?
Each of the four igniter assembly is connected by a wire with female spade connectors at each end to the 4 Pt. Reigniter unit identified as wire nos. 31 32, 33 and 34 on the wire diagram SGCS304 20-02-557 D
  • Asit Bhattacharyya
    Asit Bhattacharyya Apr 23, 2015
    I thought my description of the wires I need was clear. There are four igniters, one for each burner. Each igniter needs to be connected to the 4 Pt. Re-igniter unit by a wire.
    Top Expert:
  • Thermador Master
  • 10,875 Answers
Cooktop short circuits the electrical fuse when plugged in
Try removing parts or connections until the fuse does not blow.
With a gas hob, you are limited to a short in the ignition system.
As the igniter has failed try removing it. This should solve the fuse problem, if it doesn't, look for a short in the wiring.
Jan 09, 2012 | Thermador 46 in. SGSX456 Gas Cooktop
Thermador cooktop won't light it has the ignite
try to clean a little bit the head of the sparkler and push the button for gas a little bit longer
Mar 11, 2010 | Thermador 31 in. SGS304Z Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador SGS304 Ignitor does not spark
Hey Frust1
check that the particular burner is properly "grounded" see that no "dirt" is between burner and frame. Also ensure that the insulation on the wire from the igniter unit to the probe at the burner is not damaged.
Regards
Aug 14, 2008 | Thermador SGS36GS Gas Cooktop
Thermadore cooktop SGCS365RS
if its one of the center burners witch has the auto on off for extra low its the moduel under the handle
Potentiometer
Jul 19, 2008 | Thermador SGS36GS Gas Cooktop
One burner has no spark for ignition..
The problem is that the wire is shorting out where the black area is, that's what is causing the black mark.
It is called a pizo lighter, you will only need the section that is faulty, depending on the make/model (some require you to buy the whole pizo assembly).
You can get them from most plumbing suppliers and you should be able to get them from the retail outlet you would purchase the unit from. In each case they will have to order it in.
This is a tricky installation, and will just do the same thing if not completed properly, so if you are not totally sure of the task, please ring a plumber.
Jan 02, 2008 | GE Profile JGP636 Gas Cooktop
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
Cooktops Logo
198 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
